Legion Go 2 Fan Control
First post on Bazzite forums, but I’ve used it in three systems so far and adore it!
I threw Bazzite on the Legion Go 2 yesterday, and I’m having issues with the fan control. In HHD, I’ve unchecked Enforce Windows Minimums and played around with several different curves to try and tackle the noise issue.
The problem I’m running into is that, while Full Speed absolutely works (the fans spin up instantly), it seems to ignore my fan curve. It’ll spin up as soon as temps get to 60c and spin back down even though I’ve tested with several curves that attempt to keep it flat. This seems like default Legion behavior since it basically rubber bands from 60c → spin up loud → get back down to 50c → throttle back → repeat.
I’ve also tried the Legion Go Remapper from Decky just to see if that fixes it, but I have the same results (and have since uninstalled it, leaving only HHD).
Is there something I’m missing that I need to do in order to get it to respect fan curves I’ve set? It’s the one thing keeping it from being almost perfect!
Unfortunately, I have the same problem, and it seems that something deep within the system isn’t working properly :disappointed_face:
Whether it’s manual settings, Windows mode, or simply the default settings, nothing is really satisfactory in this regard.
Hello! I got fed up with my Legion Go 2 fan revving up and down at high speeds regardless of light or heavy games, so I ended up building a tool to bypass minimum fan speed limits and get full control.
It’s called LeGo2 Fan Control. Unlike other fan control implementations, LeGo2 Fan Control directly overrides system/EC control, so your custom curves actually work and your fan speeds hold. I’ve also included a smoothing algorithm to help prevent annoying micro-spikes in fan noise.
It’s available as a Decky Loader plugin (as well as Windows, but that’s not relevant to here).
You can download the plugin or view the source below.
I have a legion go 2 on the way right after I put bazzite on it. I’m setting up your fan control plug in as well.
