Issue updating Bazzite: PEM decoding failed
When I use System Update or use rpm-ostree update in a terminal I get this:
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite:stable
error: Creating importer: failed to invoke method OpenImage: failed to invoke method OpenImage: parsing public key 1: PEM decoding failed
Searched around but did not find anything similar. Let me know if there is anything else I can try or provide for further information if needed.
having the same exact problem here, did you happen to find a fix?
Yes, I was able to rollback using the rpm-ostree rollback command. I thought I had tried that option earlier but it worked when I tried later. I posted an issue on the githuib and it has more details on steps I did along the way.
Hope that helps you out as well.
