Issue installing certain packages using Nix
Hi, all. I’m currently daily driving Bazzite and installed Nix to manage packages instead of using Homebrew. Specifically, I’m using home-manager and flakes to manage everything, and it has mostly been working great. Installing packages like eza, jq, and ripgrep works without a hitch. However, one issue I’ve run into is that if I try to install packages like Go or Node, I get an error like so:
error: opening file '/nix/store/dbgxyznjpwxrsxykdnlh15q1g9xv3lvr-go-1.22.3.drv': No such file or directory
My understanding is that this derivation file should be generated when resolving my configuration. One thing I thought is perhaps this is getting put in the wrong directory, so I tried searching for any file with go-1.22.3 in its name across my system but there is nothing to be found.
Interestingly enough, if I use devenv to set up a development shell and specify these languages to be installed, it works perfectly.
Has anyone else come across this issue? I can’t quite understand why the files don’t get generated/ don’t exist. Below I’ve pasted my flake.nix and home.nix.
flake.nix
  description = "Atomic Nix";
  inputs = {
    nixpkgs.url = "github:nixos/nixpkgs/nixpkgs-unstable";
    home-manager = {
      url = "github:nix-community/home-manager";
      inputs.nixpkgs.follows = "nixpkgs";
  outputs = {
    nixpkgs,
    home-manager,
  }: let
    # system = "aarch64-linux"; If you are running on ARM powered computer
    system = "x86_64-linux";
    pkgs = nixpkgs.legacyPackages.${system};
  in {
    homeConfigurations = {
      "jh" = home-manager.lib.homeManagerConfiguration {
        inherit pkgs;
        modules = [
          ./home-manager/home.nix
home.nix
{ config, pkgs, ... }:
  # Home Manager needs a bit of information about you and the paths it should
  # manage.
  home.username = "jh";
  home.homeDirectory = "/var/home/jh";
  # This value determines the Home Manager release that your configuration is
  # compatible with. This helps avoid breakage when a new Home Manager release
  # introduces backwards incompatible changes.
  # You should not change this value, even if you update Home Manager. If you do
  # want to update the value, then make sure to first check the Home Manager
  # release notes.
  home.stateVersion = "24.05"; # Please read the comment before changing.
  # The home.packages option allows you to install Nix packages into your
  # environment.
  home.packages = with pkgs; [
    # # Adds the 'hello' command to your environment. It prints a friendly
    # # "Hello, world!" when run.
    firefox
    neovim
    bat
    eza
    ripgrep
    fd
    jq
    yq
    xclip
    wl-clipboard
    devenv
    zellij
    go
    # # It is sometimes useful to fine-tune packages, for example, by applying
    # # overrides. You can do that directly here, just don't forget the
    # # parentheses. Maybe you want to install Nerd Fonts with a limited number of
    # # fonts?
    # (pkgs.nerdfonts.override { fonts = [ "FantasqueSansMono" ]; })
    # # You can also create simple shell scripts directly inside your
    # # configuration. For example, this adds a command 'my-hello' to your
    # # environment:
    # (pkgs.writeShellScriptBin "my-hello" ''
    #   echo "Hello, ${config.home.username}!"
  # Home Manager is pretty good at managing dotfiles. The primary way to manage
  # plain files is through 'home.file'.
  home.file = {
    # # Building this configuration will create a copy of 'dotfiles/screenrc' in
    # # the Nix store. Activating the configuration will then make '~/.screenrc' a
    # # symlink to the Nix store copy.
    # ".screenrc".source = dotfiles/screenrc;
    # # You can also set the file content immediately.
    # ".gradle/gradle.properties".text = ''
    #   org.gradle.console=verbose
    #   org.gradle.daemon.idletimeout=3600000
  # Home Manager can also manage your environment variables through
  # 'home.sessionVariables'. These will be explicitly sourced when using a
  # shell provided by Home Manager. If you don't want to manage your shell
  # through Home Manager then you have to manually source 'hm-session-vars.sh'
  # located at either
  #  ~/.nix-profile/etc/profile.d/hm-session-vars.sh
  # or
  #  ~/.local/state/nix/profiles/profile/etc/profile.d/hm-session-vars.sh
  # or
  #  /etc/profiles/per-user/jh/etc/profile.d/hm-session-vars.sh
  home.sessionVariables = {
    # EDITOR = "nvim";
  # Let Home Manager install and manage itself.
  programs.home-manager.enable = true;
Oh! you can use devenv on Bazzite? That’s so cool. I may want to do that.
I’m new to Atomic desktops and still learning where the edges are.
wrt your compiler problem, I wonder if you need to use home-manager or Flatseal to grant access to … something?
Yup! It’s quite awesome.
As for my problem with Nix, I’m still at a loss. I would think it would create the derivation and place it where every other package gets placed but it just doesn’t seem to work. I have the same problem with direnv btw.
Maybe I’m missing something with how Nix interacts with Silverblue, but it’s just weird how some packages work fine and others don’t.
Hey, all. I just wanted to update that I finally got everything working. I’m still not sure why there was a problem, however my solution was basically to just uninstall nix + home-manager and re-install.
Since I installed using the nix determinate installer, I followed their instructions to uninstall, rebooted, and then reinstalled. I then ran nix run nixpkgs#home-manager -- switch --flake nix/#$USER to reinstall home-manager while pointing to my flake in my ~/nix directory. It prompted me that there were conflicts with my home-manager profiles, so I deleted them all and tried again. (the installer prompts you which files to remove). After that, I was able to build successfully!
Hope this helps some one else in the future.
