werner
1
I find it difficult to stay up to date regarding the project.
When entering “ujust” I dont see “nix” or “homebrew” anywhere.
This may be a downstream issue in secureblue?
The nix install was broken for me anyways, so I would like to remove it
sudo btrfs subvolume delete /nix didnt work.
Thanks!
j0rge
2
Follow the announcement tag to get updates in your inbox: Topics tagged announcements
Or you can star whatever image you use and you’ll get per commit updates in your inbox: Saving repositories with stars - GitHub Docs
Not sure what custom image you’re on so not sure what your just config has or doesn’t have.
I’m having the same issue. IDK at which point nix was removed from default installation and now I want to get rid of it.
I’m considering backing up my personal data and making a fresh installation… will be the cleanest way
Ok, I think I got it.
First I ran home-manager uninstall. Then, digging through the repo it was uninstalled through ujust
So I ran /nix/nix-installer uninstall.
It worked for me!
werner
7
Nice!
I found another strange thing, SDDM shows me a ton of Nix users but only on the fallback theme.
They dont show like normal users, need to search where SDDM gets its users.
Would be nice to have a way to remove them too.
