Is this supported?
In the middle of the installer I’m getting a black screen with random glimpses of the ui…
Is this supported?
I’m not sure if this post is visible or not.
It is, I think we’re just waiting to see if someone else has tried it.
Ah thanks. I used the nvidia image maybe that’s the problem?
Yeah it is, don’t worry
It could, but I don’t think it should be that
I have found 2 issues that are Fedora related, not bluefin related.
From previous experience VMware lags on some things and Fedora occasionally breaks as a guest, especially if you try to stay on the latest. I’d prefer it but just find Ubuntu lts less hassle in a vm.
