Nvidia 565.57 not turning on 2nd monitor
565.35x works great in aurora 40 but 565.57x deactivates 2nd monitor
Nvidia gtx 1650
Inatalled fresh copy of bluefin which has 565.57x fails
Baffled … any idea to why… and please responses with (works for me dosnt help)
what exact version/tag did you install? Can you find any related logs? If possible could you run journalctl -xf before you attach the screen and then check if there is something suspicious?
I have tried my monitor connected to the displayport uaing Bluefin Stable on a Dell XPS 15 7590 with Nvidia Turing gpu and it worked
No updates and monitors connected via hdmi. Both turnes on on 565.35x no issues.
SolusOS just updated to 565.77x and everything works great.
Aurora and bluefin craps out 2nd monitor on 565.57x
Cant be bothered with this nonsense need to get work done. Parked up bluefin and aurora for awhile and using solusOS and getting work done for now. Perhaps in a number of weeks or mths bluefin or aurora may upgrade to 565.77x . I know its all ublue upstream but come on guys… how about vetting it and a bit of qa can go a long way like other distros do
Use whatever gets your work done. But just to let you and others know if the problems are fixed in 565.77, looking at the stable release notes from yesterday bluefin-nvidia:stable should be on that version.
Newest Aurora (also stable) that was built just now, should also have the new nvidia drivers.
Will check out in near future and thanks for the heads up
