Hi,
I recently installed Bluefin on a Thinkpad T480 with Intel Graphics. At first everything worked fine, but then i noticed applications that I don’t use as often on this device now rendering properly (other things like the terminal or Chrome however are fine).
One application that does not work is Anytype, which is installed via appimage:
The other app where this also occurs is the vs code installation which comes with the os. When running code from an Ubuntu toolbox it properly renders however.
[screenshot removed because of posting limitation]
Output of ujust device-info: UNTITLED - Pastebin Service
