So yesterday I installed Bazzite for the first time on my computer. I continued with the pre-installed steam package.
I’m using an Intel cpu and an AMD RX6600 on wayland Plasma 6. Games are working fine but I’m not able to use the in-game steam overlay. Some games like Apex legends rely on it to complete a sign in process. Apex is saying that I don’t have in-game overlays enabled, when I clearly have it enabled (for the game and within the gernal steam settings) . I tried changing the keys from the default ‘Shift+Tab’ but still no luck.
Does anyone have a solution for this ? Or should I install flatpak steam on Bazzite ?
Edit : It seems that I’m also not able to add steam libraries from other drives, not working with ntfs partitions and btrfs partitions. This was fixed randomly after a couple of reboots
Edit 2: Now when I open steam, the display blacks out and makes it unusable. Occasionally I’m able to see the desktop but it blacks out gain if I open a window or move my mouse in some cases.
I’m aware that using X11 can solve some issues (screen black out issue is there in X11 as well), however I want to use wayland. Any solution to the above mentioned issues are much appreciated.
