Focus follows mouse
I prefer using the “Focus follows mouse” window activation policy. I like being able to eliminate that extra click.
The only issue I have with this is that the KDE panel does not seem to qualify as a window. What this means is that when I hover my mouse over the panel to interact with it, I am forced to click twice: once to bring focus to the panel and a second time to actually activate what I wanted to activate.
Is there a way to enable the panel to be activated simply by hovering over it? Thanks!
Edit:
The panel does actually get selected on mouse hover. It was the activation delay that was tripping me up into thinking it wasn’t working. Once I lowered the delay my issue went away.
Okay, so it’s not quite straightforward like my original post or edit. I’m guessing this is a bug in KDE. It would be great if someone could confirm they’re experiencing this issue.
I’m using “Focus follows mouse (mouse precedence)”.
When I have an application minimized to the task manager on the panel and hover over the panel icon to re-focus and pop the window back up, everything works as expected. If I hover from another app over to the panel, click once on the minimized app’s icon, then the window immediately pops back up as it should.
However, if I want to minimize an open app window, things don’t work like that. When I mouse over the panel from within the app window or any other part of the desktop, clicking the icon doesn’t cause the window to minimize. Instead, I need to click twice for the app to actually minimize.
The reason I think this is a bug and not intended behavior is that if I never let my mouse leave the panel, I can minimize and re-focus the app window as many times as I want with just one click after the initial double-click event.
