Fastfetch config issue
Greetings all,
Enjoying Bazzite and getting it setup they way I like.
Currently having an issue getting fastfetch to use my config.
I have it in ~/.config/fastfetch but it is not being used.
If I run:
fastfetch -c ~/.config/fastfetch/config.jsonc
It gives me this error:
Error: only one config file can be loaded
Looks like fastfetch is reading the config in /usr/share/ublue-os/bazzite/
Any way to get it to use my config?
Thanks
It’s in /etc/profile.d/bazitte-neofetch.sh
That file is just aliases that points to /usr/share/ublue-os/bazzite/
And since immutable I can not change correct?
Change the line in that file to point to your config, or remove it entirely from that file and it won’t alias it to anything.
You could also alias it in your home directory and that should take precedence over your system one.
Ok I modified the file with nano.
Gnome-text-editor would not save it.
Thank you for the help!
All is working thanks again j0rge.
