Docker Container networking failing
I am unable to get networking in any docker container on Bluefin gts (F39). Podman containers get networking just fine but docker does not. It is a bit maddening!
I’ve been testing this command:
docker run --rm nicolaka/netshoot ping -c4 1.1.1.1
If I do the same with podman it works great! I want to get setup with using the supported docker+devcontainer environments. Any tips on where to start with this? Is firewalld blocking everything? How do I check that?
I’m going to try rebasing to F40.
Not sure I can help, as everything worked out of the box for me.
The first question, as it always is, is have you rebooted?
This Stack Overflow thread has a lot of discussion about docker networking.
On the host OS on my machine, this is the info for the docker0 bridge:
❯ ip addr show docker0
6: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default
    link/ether 02:42:1f:a3:b0:cd brd ff:ff:ff:ff:ff:ff
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
       valid_lft forever preferred_lft forever
    inet6 fe80::42:1fff:fea3:b0cd/64 scope link proto kernel_ll
And this is the iptables setup:
❯ sudo iptables --list
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
DOCKER-USER  all  --  anywhere             anywhere
DOCKER-ISOLATION-STAGE-1  all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
DOCKER     all  --  anywhere             anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (2 references)
ACCEPT     tcp  --  anywhere             172.18.0.2           tcp dpt:ms-wbt-server
ACCEPT     udp  --  anywhere             172.18.0.2           udp dpt:ms-wbt-server
ACCEPT     tcp  --  anywhere             172.18.0.2           tcp dpt:wpl-analytics
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2  all  --  anywhere             anywhere
RETURN     all  --  anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-2 (2 references)
DROP       all  --  anywhere             anywhere
Chain DOCKER-USER (1 references)
RETURN     all  --  anywhere             anywhere ```
I did a completely fresh reinstall and I can confirm docker has networking. @JohnAtl thanks for taking the time to respond :slightly_smiling_face:
I will try to keep track of different config changes.
I’m trying out the Microsoft VSCODE-REMOTE-TRY-PYTHON devcontainer now. This tech is really cool! I like how the developer environment is based on how we ship applications in the cloud.
Cool!
I don’t deploy containers, so will take your word on that.
This is the basis for my Dockerfile
nvcr.io/nvidia/tensorflow:24.05-tf2-py3
Then I add Python 3.11 from deadsnakes , some command line stuff and vs code extensions, also code to run as my user in the container and not root.
It was challenging to learn and get set up, but now it’s pretty much bullet proof. If I should lose the container for some reason, I can just rebuild it.
For our next project, I’ll use a newer version of Tensorflow and Python, and build a new container. No problems with versions, venvs, etc. if I need to switch between projects.
Is tensorflow for machine learning and AI applications?
I was starting to use nix for developer environments but I like this method better so far. The devcontainer method is mainstream and there are a lot more knowledge resources for docker and containers.
Yes, Tensorflow is for ML/AI.
I’ve tried nix several times, but there’s just too much overhead. Maybe if I were deploying a fleet of machines it would be worthwhile. Homemanager was equally painful.
