Disable PS5 controller touchpad?
Hey guys, I borrowed my brothers PS5 controller to play Jedi Survivor so that I could have the trigger feedback that’s exclusive to the PS5 controller, and while everything worked just fine, the touchpad insists on acting like a mouse, which locks me out of the intended functions of the games use of the touchpad.
I’ve already searched and haven’t come up with any Linux solutions for getting the PS5 controllers touchpad to act the way it’s intended to in games. At first I thought it was cool that I could use the touchpad as a mouse, but then I realized I can’t open the map in game because as soon as I put my finger on the touchpad it acts as a mouse.
If anyone could help me find a solution to this problem, it would be greatly appreciated!
You can check out Steam input profiles. For a few games the default input method is weird, I especially noticed this with my DualSense and Sixaxis DualShock controllers.
In Gaming Mode it’s the controller shaped button on the right side, within Game View.
Depends on whether you are on the deck image or in the desktop image. Deck image contains ds-inhibit, which will autodetect steam and turn off the touchpad.
If not, and you will use the Dualsense with games that support it and steam, turn off the kernel module hid_playstation which will do the same. Although the compatibility of the controller with non-native Dualsense games will be reduced.
I’m on the desktop image of Bazzite. Can I install ds-inhibit using distrobox to access the AUR?
I’ve tried searching and I don’t quite understand how to disable the kernel module you mention. I’m sorry, I’m still pretty new to Linux. How do I go about doing that?
Thank you for the help!
Dont worry about ds inhibit and do not try to add it.
echo 'blacklist hid_playstation' | sudo tee /etc/modprobe.d/playstation.conf
Then reboot, the touchpad will stop working.
To undo, sudo rm /etc/modprobe.d/playstation.conf
I just wanted to share advice for anyone finding this thread on the desktop image who actually WANTS to enable the touchpad as a mouse:
As mentioned above, ds-inhibit is the culprit. So to disable it:
  1. Disable the systemd service: sudo systemctl disable --now ds-inhibit.service
  2. Optionally mask the service to prevent it from being automatically enabled again: sudo systemctl mask ds-inhibit.service
Apologies to bump an old thread, if this is poor etiquette and I should share this info somewhere else I’d be glad to, just let me know where.
