Is it possible to uninstall HHD from bazzite and use something like simpledeckyTDP instead? and will it cause problem to the point it’s not even worth it?
You can just use SimpleDeckyTDP, HHD will turn off it’s own TDP controls if you install SDTDP.
Later on, if you want hhd TDP controls back, you can just uinstall SDTDP.
If I turn off hhd what controller type would it default too? Steam controls?
