Can't get Xbox Wireless Controller to work over Bluetooth
As the title says, I can’t get the Xbox Wireless Controller to work via Bluetooth. I can initially pair with it, but right after the settings report the controller as paired, the LED on the controller keeps flashing as if it wasn’t connected. When I wait for the controller to time out and turn off automatically (or turn it off manually), then turn it back on again, it keeps connecting/disconnecting continuously, very fast.
What could be the cause of this? I don’t know if it is Bazzite/Ublue specific or if it also happens on other distributions.
Btw should I report this as an issue on the Bazzite GitHub?
I have seen this in the past with Linux, for me, it was older firmware on my controllers, I had to update them on a Windows machine via the Xbox app, after doing that they work properly.
The other thing to try is a different Bluetooth dongle, I have a few of these, ranging from v4 to 5.3 and it can be a mixed bag on which one works best, this is not a Bazzite thing, more of a Linux thing, but with the latest Kernel, all of my Bluetooth dongles are working, and all of my Xbox controllers function perfectly, and I have a mix of the older ones, and the newest ones with USB-C.
Ah updating the controller is maybe a good one, I will do that. I don’t have a Bluetooth dongle unfortunately, I am just using the built-in Bluetooth on my pc.
I updated my controller firmware via the Xbox Accessories app on Windows and now it does indeed work. I still have to test it with gaming but at least the connection is stable and Steam does recognize and is able to interact with the controller.
I thought this might work, shame you need Windows to do it though.
Yeah :cry: although I think it should also be possible on an Xbox.
But this way I’ll never get rid of needing to have Windows on at least one system (or dual boot / VM, although idk if VM would cover all cases with regards to hardware passthrough).
I started using Bazzite around a month ago (dual boot for now) and the experience has been mostly positive, but I discovered strangely enough that the things that hold me back the most is not actually gaming (that part has really really been improved on Linux also thanks to Valve and things like Proton and the Steam Deck), but due to various applications and peripherals that I use in my system that are really proprietary and closed source and I didn’t realize that beforehand.
Things like my Logitech peripherals (keyboard, mouse, headphones), my NZXT AIO watercooler, Microsoft OneNote, Apple Music.
Sure, basic functionality often works, but for example for OneNote and Apple Music I have to use the web versions which are missing some functionality and are slower. And on the hardware side, vendors like Logitech and NZXT only release applications for Windows (and sometimes Mac OS) which you need to control things like changing the LED colours and more advanced features. Often applications for updating firmware for SSDs etc. is only released for Windows.
It is in that way that I still very much notice the monopoly of Windows in the world.
I learnt a long time ago, to stop purchasing things that need specific closed software to function, even when I use Windows, I use Logitech peripherals, but I never install their software, I have been where you are with NZXT, Razer and many other brands, and I make sure when I build my systems, they are as open as possible, I won’t use any AIO that requires additional software, I highly recommend Arctic gear in this regard, I wont even install my motherboard vendor software, only the main drivers direct from the chip manufacturer.
My approach now, if it requires proprietary software, a smart phone, wifi, or some silly online account for it to work properly, then its gone, this process is why I have started using Bazzite on some of my systems, and I only use Windows on my workstation, as I need to use particular CAD software, I have no choice at the moment, but all my other machines, run Debian, Fedora, Arch, and even Ubuntu.
I even block that garbage software that auto install’s itself like that crap Nahimic and other similar junkware, oh and I rejected OneNote straight away, on the very first Surface I ever owned, the first thing I found is I couldn’t just save the text to a text file, or any other kind of document its vile and disgusting pile of crap software, and that was like 10yrs ago, try Rnote on Linux.
You may also find, a lot of those products can and do run just fine without all of that bloatware, its just you are used to having these additional walled features, I’m personally done with all that, I ditched Apple Airpod Pro’s for some Nothing Ears 2, they work just as good, and require no additional software for Windows, Linux, Android or IOS, for better Audio, I went with Sony XM5’s, these also work the same, no additional software or account BS required.
This website is quite informative: FUTO Self Managed Guide
And this is another really good source of information: Mission statement - Consumer Rights Wiki
This fixed the problem for me as well, thanks. Unfortunately I had to go and find someone with an XBOX. Once I plugged it in it immediately popped up asking me to update the firmware. Very easy to do on XBOX. Impossible to do on Windows. I couldn’t even get the accessory app to download. Kept saying the system needed to be updated but it was already up to date.
Unfortunately XBOX controllers are the only controllers I can find with swappable batteries and I’m just not willing to compromise on that with any other controller.
Yes the old school batteries are a good feature, I use the official lithium packs in mine and have a USB-C powerbank with a magnetic cable for my setup, if the batterie is low, I just connect the cable and let it charge while I play, and it can pull off easy like a magsafe connector.
Why this happens:
Bazzite (and Linux in general) stores Bluetooth pairing info under /var/lib/bluetooth. If a previous pairing with the controller failed or broke, the system may silently ignore that device instead of showing it again in the scan. The GUI doesn’t show any error, it just “doesn’t see” the controller.
What fixed it for me:
Turn Bluetooth OFF
Delete the old controller data (this part uses the terminal)
Open a terminal
First, list what’s inside /var/lib/bluetooth:
sudo ls /var/lib/bluetooth
You should see a folder that looks like your controller MAC address, for example:
54:8D:5A:D8:1B:BF
That folder is the stored data for your controller. Remove it:
sudo rm -rf /var/lib/bluetooth/54:8D:5A:D8:1B:BF
(Replace 54:8D:5A:D8:1B:BF with whatever folder name you actually see.)
Turn On Bluetooth and Scan again.
I tried this just how you said, but it unfortunately didn’t work. Is there anything else I could try or something I could have missed? Sorry, I’m brand new to Linux and I’m not sure where to start looking
have exactly the same issue with OP
using sudo rm -rf /var/lib/bluetooth/XX..
  • on Bazzite Deck (v43): Deleting the directory resolved the issue.
  • on Bazzite Desktop Edition (v44): Unsuccessful.
My system dont see my Xbox controller, but i found a way to fix it, the problem mainly was in Privacy setting at: /etc/bluetooth/main.conf and BLE mode on my usb bluetooth adapter, as Xbox controllers use BLE mode to pair. Here is what helps, i find that fix with chatgpt and ask him to make a tuto:
Xbox Controller not detected over Bluetooth on Bazzite/Linux — fix for CSR/Barrot 0a12:0001
I ran into an issue on Bazzite KDE where an Xbox Wireless Controller worked perfectly over USB and also connected normally over Bluetooth in Windows, but Bazzite/Linux could not detect it at all.
Bluetooth adapter:
ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle
However, bluetoothctl show reported manufacturer 2279, which means this is actually one of the Barrot-based adapters that identifies itself using the old CSR USB ID.
The following errors appeared during scanning:
org.bluez.Error.InProgress
and with btmgmt:
Unable to start discovery. status 0x0d (Invalid Parameters)
What fixed it
In my case, the problem was related to Bluetooth Privacy.
Open:
sudo nano /etc/bluetooth/main.conf
Under the [General] section, set:
Privacy = off
Important: if you previously had:
Privacy = network
replace it with off.
Save the file and restart Bluetooth:
sudo systemctl restart bluetooth
Then reset the Bluetooth controller settings with:
sudo btmgmt power off
sudo btmgmt privacy off
sudo btmgmt le on
sudo btmgmt bredr on
sudo btmgmt power on
Check the current state:
sudo btmgmt info
Under current settings, the regular privacy flag should no longer be present.
ll-privacy may still remain — that is fine.
Test Xbox Controller discovery
Put the Xbox Controller into pairing mode so the Xbox button is flashing rapidly.
Run an LE-only scan:
sudo btmgmt find -l
After applying the fix, my controller immediately appeared:
name Xbox Wireless Controller
type LE Public
So BLE discovery was finally working correctly.
Pair the controller
Stop the low-level scan:
sudo btmgmt stop-find
Then start:
bluetoothctl
Inside bluetoothctl, run:
power on
agent on
default-agent
scan le
Once the Xbox Controller appears, note its MAC address, for example:
68:6C:E6:59:1C:43
Then run:
pair 68:6C:E6:59:1C:43
trust 68:6C:E6:59:1C:43
connect 68:6C:E6:59:1C:43
You can verify the connection with:
info 68:6C:E6:59:1C:43
A successful result should look similar to:
Paired: yes
Bonded: yes
Trusted: yes
Connected: yes
After that, the Xbox Controller should work normally over Bluetooth in Bazzite/Steam.
Short version
If Bazzite/Linux detects your adapter as:
but cannot find your Xbox Controller, try:
# /etc/bluetooth/main.conf
[General]
Privacy = off
Then run:
sudo btmgmt le on
sudo btmgmt find -l
In my case, disabling Bluetooth Privacy immediately fixed BLE scanning, and the Xbox Wireless Controller became visible and connected successfully.
One more note: run btmgmt commands with sudo. Without it, you may get:
status 0x14 (Permission Denied)
Also, if the controller is detected with a very weak RSSI such as -90 to -100, keep it close to the Bluetooth dongle during the first pairing attempt.
