CALL TO ARMS: Modern Sleep on Ayaneo AMD Ryzen 7000+
Hello guys, as you already know sleep is not working on Linux on many Ayaneo devices.
There is no hardware limitation whatsoever and it’s just a bios configuration issues that is easily fixed with the method shown on chimeraos’'s, bazzite’s and steam fork’s wiki.
That is an easy fix but it is not permanent as it sometimes reset itself.
I’ve tried to contact Ayaneo with no success or meaningfull reply and I suspect this is due to the idea that not many users are affected.
I think we may obtain more if we show them that there is a decent amount of people using Linux on their devices.
Since they are a small company and hard workers there is no need to be aggressive but we just want to show that we exists. This is the message I’ve sent, use it as template.
*Hello there,
As I am sure you know and stated here Troubleshooting - SteamFork Wiki there is a desperate need for bios update for any users who uses Linux on ayaneo handheld with AMD Ryzen series 7000.
Most of the devices are nowadays perfectly fine under Linux exception made for sleep which is a crucial part of playing on the go.
The fix is there but the solution provided across the forum’s are prone to be reverted when there is a bios reset. A properly configured bios fix should be easy to apply, requires virtually no testing and according to my tests does not affect windows or ayaspace application which I use on a daily base.
I wish you could take time to look into it.
Love
You can find contacts information at the bottom of:
Ayaneo updated their bios for 2s and air 1s!!
Geek 1s is still missing though.
I wonder if what they are doing is even working. Can someone with 2s/air 1s confirm?
I was Looking at the bios update file it and it looks like it consist of the previous update and .reg +exe files for windows. I am not sure it will be anything useful for Linux. I only looked briefly though
The update fixed sleep on supported models as shown here
https://www.reddit.com/r/ayaneo/s/3ebyuDwWoQ
