mt7921e is the wireless chip in Ayaneo Air. It suffers from failing to recover from sleep. There is a workaround to fix it: remove kmod mt7921e before sleep, and insert it after sleep. Hope you can add this quirk into ujust menu, thanks a lot. ![]()
Here is reference from ChimeraOS: https://github.com/ChimeraOS/device-quirks/blob/c9a0d99d3897a09c10f2e9f27dba1fb5fb312144/usr/lib/systemd/system-sleep/systemd-suspend-mods.sh
