Bluefin randomly freezes
I’ve been having trouble with Bluefin freezing on my latest install. I’m using a Lenovo ThinkCentre M715Q 256GB, AMD Ryzen 5 2400GE, 3.2 GHz, 16gb Ram. Is there a way to Ctrl+Alt+Delete to get it unstuck? I remember using a way to kill a program when I used KDE years ago. Also, where would I look to determine what is causing it to freeze? So far, pushing the power button to shut it down is the only way to get out of it. When I reboot, it’s working again.
Thanks.
System Details Report
Report details
  • Date generated: 2025-01-07 12:59:33
Hardware Information:
  • Hardware Model: Lenovo ThinkCentre M715q
  • Memory: 16.0 GiB
  • Processor: AMD Ryzen™ 5 PRO 2400GE w/ Radeon™ Vega Graphics × 8
  • Graphics: AMD Radeon™ Vega 11 Graphics
  • Disk Capacity: 2.3 TB
Software Information:
  • Firmware Version: M1XKT63A
  • OS Name: Bluefin 40 (FROM Fedora Silverblue)
  • OS Build: eb2ac92
  • OS Type: 64-bit
  • GNOME Version: 46
  • Windowing System: Wayland
  • Kernel Version: Linux 6.11.8-200.fc40.x86_64
I switched to stable, and it’s still freezing. I also had it freeze today with another computer.
I had the problem with a freezing system with fullscreen applications. E.g. when watching a youtube video in firefox in fullscreen.
For me it helped to use flatseal to change the firefox flathub package to only use X11 and disable Wayland. Also add this environment variable in flatseal for firefox :
I’m not using Firefox or watching videos when it happens. Unfortunately, it froze three times today.
Im having the exact same issue on a wildly different system:
How did you find the error log? How did you find the critical errors?
What you can try is to rebase to the -latest stream. Atleast that way you can check if its a kernel regression, which is pretty likely knowing all the issues AMD has been having with its kernel drivers.
I rebased to -latest and it’s still freezing.
Had a similar issue with Bluefin on RHEL40 a while back, but I am Bluefin DX Latest and the locking issue is now resolved. It looked like an issue with the video driver, I was able to do a crtl-alt-F3 or F4 to get to the command line, it took a while as the system was doing a coredump. I opened a BZ for the issue, but it didn’t get much traction.
https://bugzilla.redhat.com/show_bug.cgi?id=2312304
I reinstalled bluefin but it still froze. I tried crtl-alt-F3 and F4, but neither worked.
When it freezes, restart and run ujust logs-last-boot to see what errors are occurring. The lines near the end should give some indication of what is going on before it froze.
This is the last part of the logs. There were thousands of entries:
BlockquoteJan 27 10:13:25 systemd[1]: run-media-root-7C6C\x2d5F3E.mount: Deactivated succ>
Jan 27 10:13:25 udisksd[1100]: Cleaning up mount point /run/media/root/7C6C-5F3>
Jan 27 10:13:25 udisksd[1100]: Unmounted /dev/sda3 on behalf of uid 0
Jan 27 10:13:26 audit: BPF prog-id=74 op=LOAD
Jan 27 10:13:26 systemd[1]: Starting passim.service - Local Caching Server…
Jan 27 10:13:26 avahi-daemon[1060]: Missed message org.freedesktop.DBus.Propert>
Jan 27 10:13:26 passimd[3417]: failed: failed to register: http server has not >
Jan 27 10:13:26 systemd[1]: Started passim.service - Local Caching Server.
Jan 27 10:13:26 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 10:13:26 fwupd[3345]: 15:13:26.370 FuMain Daemon ready for>
Jan 27 10:13:26 systemd[1]: Started fwupd.service - Firmware update daemon.
Jan 27 10:13:27 systemd[1]: fprintd.service: Deactivated successfully.
Jan 27 10:13:27 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:13:27 audit: BPF prog-id=73 op=UNLOAD
Jan 27 10:13:27 gnome-shell[2570]: GNOME Shell started at Mon Jan 27 2025 10:13>
Jan 27 10:13:27 gnome-shell[2570]: Registering session with GDM
Jan 27 10:13:27 gnome-shell[1461]: Connection to xwayland lost
Jan 27 10:13:27 systemd[1]: run-user-42-doc.mount: Deactivated successfully.
Jan 27 10:13:27 xdg-document-po[2157]: Error releasing name org.freedesktop.por>
Jan 27 10:13:27 gdm-launch-environment][1353]: pam_unix(gdm-launch-environment:>
Jan 27 10:13:27 audit[1353]: USER_END pid=1353 uid=0 auid=4294967295 ses=429496>
Jan 27 10:13:27 audit[1353]: CRED_DISP pid=1353 uid=0 auid=4294967295 ses=42949>
Jan 27 10:13:27 systemd-logind[1097]: Session c1 logged out. Waiting for proces>
Jan 27 10:13:27 systemd[1]: session-c1.scope: Deactivated successfully.
Jan 27 10:13:27 systemd[1]: session-c1.scope: Consumed 7.119s CPU time, 465.5M >
Jan 27 10:13:27 systemd-logind[1097]: Removed session c1.
Jan 27 10:13:27 gdm[1325]: Gdm: Child process -1436 was already dead.
Jan 27 10:13:28 gnome-shell[2570]: OpenWeather Refined: Failed to fetch weather>
Jan 27 10:13:28 gnome-shell[2570]: OpenWeather Refined: getWeatherInfo failed w>
Jan 27 10:13:31 gnome-software[2780]: Tried to set invalid release date: YYYY-M>
Jan 27 10:13:35 nautilus[3243]: GSConnect: [Errno 2] No translation file found >
Jan 27 10:13:35 nautilus[3243]: open-any-terminal: terminal is set to “ptyxis” >
Jan 27 10:13:35 gnome-software[2780]: Tried to set invalid release date: YYYY-M>
Jan 27 10:13:35 systemd[2252]: Started app-flatpak-com.google.Chrome-3551.scope.
Jan 27 10:13:35 systemd[2252]: Started app-gnome-com.google.Chrome-3551.scope →
Jan 27 10:13:36 systemd[2252]: Reached target gnome-session-x11-services.target>
Jan 27 10:13:36 systemd[2252]: Starting org.gnome.SettingsDaemon.XSettings.serv>
Jan 27 10:13:36 gnome-shell[3596]: The XKEYBOARD keymap compiler (xkbcomp) repo>
Jan 27 10:13:36 gnome-shell[3596]: > Warning: Unsupported maximum keyc>
Jan 27 10:13:36 gnome-shell[3596]: > X11 cannot support keyco>
Jan 27 10:13:36 gnome-shell[3596]: > Warning: Could not resolve keysym>
Jan 27 10:13:36 gnome-shell[3596]: Errors from xkbcomp are not fatal to the X s>
Jan 27 10:13:36 gsd-xsettings[3597]: Failed to get current UI scaling factor: G>
Jan 27 10:13:36 systemd[2252]: Started org.gnome.SettingsDaemon.XSettings.servi>
Jan 27 10:13:36 systemd[2252]: Reached target gnome-session-x11-services-ready.>
Jan 27 10:13:36 cobalt[3577]: Failed to load module “canberra-gtk-module”
Jan 27 10:13:36 systemd[2252]: Starting flatpak-portal.service - flatpak portal>
Jan 27 10:13:36 systemd[2252]: Started flatpak-portal.service - flatpak portal.
Jan 27 10:13:36 mutter-x11-fram[3622]: Using GtkSettings:gtk-application-prefer>
Jan 27 10:13:36 com.google.Chrome.desktop[3577]: [0127/101336.603166:WARNING:ch>
Jan 27 10:13:36 systemd[2252]: app-flatpak-org.gnome.NautilusPreviewer-3352.sco>
Jan 27 10:13:37 systemd[2252]: Started app-flatpak-com.google.Chrome-3669.scope.
Jan 27 10:13:37 com.google.Chrome.desktop[3667]: [0127/101337.353446:WARNING:ch>
Jan 27 10:13:37 chrome[3577]: Failed to load module “canberra-gtk-module”
Jan 27 10:13:37 systemd[1]: bluetooth.service - Bluetooth service was skipped b>
Jan 27 10:13:37 gnome-keyring-daemon[2279]: asked to register item /org/freedes>
Jan 27 10:13:38 systemd[1]: Stopping user@42.service - User Manager for UID 42.>
Jan 27 10:13:38 systemd[1390]: Activating special unit exit.target…
Jan 27 10:13:38 systemd[1390]: Stopped target default.target - Main User Target.
Jan 27 10:13:38 systemd[1390]: Stopping mpris-proxy.service - Bluetooth mpris p>
Jan 27 10:13:38 systemd[1390]: Stopping pipewire-pulse.service - PipeWire Pulse>
Jan 27 10:13:38 systemd[1390]: Stopped mpris-proxy.service - Bluetooth mpris pr>
Jan 27 10:13:38 systemd[1390]: Stopped pipewire-pulse.service - PipeWire PulseA>
Jan 27 10:13:38 systemd[1390]: Stopping wireplumber.service - Multimedia Servic>
Jan 27 10:13:38 wireplumber[1995]: wireplumber: stopped by signal: Terminated
Jan 27 10:13:38 wireplumber[1995]: wireplumber: disconnected from pipewire
Jan 27 10:13:38 systemd[1390]: Stopped wireplumber.service - Multimedia Service>
Jan 27 10:13:38 systemd[1390]: Stopping pipewire.service - PipeWire Multimedia >
Jan 27 10:13:38 systemd[1390]: Stopped pipewire.service - PipeWire Multimedia S>
Jan 27 10:13:38 systemd[1390]: Stopped target basic.target - Basic System.
Jan 27 10:13:38 systemd[1390]: Stopped target paths.target - Paths.
Jan 27 10:13:38 systemd[1390]: Stopped target sockets.target - Sockets.
Jan 27 10:13:38 systemd[1390]: Stopped target timers.target - Timers.
Jan 27 10:13:38 systemd[1390]: Stopped podman-auto-update.timer - Podman auto-u>
Jan 27 10:13:38 systemd[1390]: Stopped systemd-tmpfiles-clean.timer - Daily Cle>
Jan 27 10:13:38 systemd[1390]: Closed pipewire-pulse.socket - PipeWire PulseAud>
Jan 27 10:13:38 systemd[1390]: Closed pipewire.socket - PipeWire Multimedia Sys>
Jan 27 10:13:38 dbus-broker[1441]: Dispatched 464 messages @ 9(±63)μs / message.
Jan 27 10:13:38 systemd[1390]: Stopping dbus-broker.service - D-Bus User Messag>
Jan 27 10:13:38 systemd[1390]: Stopped systemd-tmpfiles-setup.service - Create >
Jan 27 10:13:38 systemd[1390]: Stopped dbus-broker.service - D-Bus User Message>
Jan 27 10:13:38 systemd[1390]: Removed slice session.slice - User Core Session >
Jan 27 10:13:38 systemd[1390]: Closed dbus.socket - D-Bus User Message Bus Sock>
Jan 27 10:13:38 systemd[1390]: Removed slice app.slice - User Application Slice.
Jan 27 10:13:38 systemd[1390]: Reached target shutdown.target - Shutdown.
Jan 27 10:13:38 systemd[1390]: Finished systemd-exit.service - Exit the Session.
Jan 27 10:13:38 systemd[1390]: Reached target exit.target - Exit the Session.
Jan 27 10:13:38 com.google.Chrome.desktop[3577]: [2:2:0127/101338.204458:ERROR:>
Jan 27 10:13:38 systemd[1]: user@42.service: Deactivated successfully.
Jan 27 10:13:38 systemd[1]: Stopped user@42.service - User Manager for UID 42.
Jan 27 10:13:38 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:13:38 systemd[1]: user@42.service: Consumed 1.174s CPU time, 33.3M me>
Jan 27 10:13:38 systemd[1]: Stopping user-runtime-dir@42.service - User Runtime>
Jan 27 10:13:38 systemd[1]: run-user-42.mount: Deactivated successfully.
Jan 27 10:13:38 systemd[1]: user-runtime-dir@42.service: Deactivated successful>
Jan 27 10:13:38 systemd[1]: Stopped user-runtime-dir@42.service - User Runtime >
Jan 27 10:13:38 systemd-logind[1097]: Removed session 1.
Jan 27 10:13:38 systemd[1]: Removed slice user-42.slice - User Slice of UID 42.
Jan 27 10:13:38 systemd[1]: user-42.slice: Consumed 8.337s CPU time, 497.9M mem>
Jan 27 10:13:40 systemd[2252]: Started app-flatpak-com.google.Chrome-4004.scope.
Jan 27 10:13:40 com.google.Chrome.desktop[3577]: Created TensorFlow Lite XNNPAC>
Jan 27 10:13:40 com.google.Chrome.desktop[3577]: Attempting to use a delegate t>
Jan 27 10:13:41 com.google.Chrome.desktop[3577]: [2:42:0127/101341.071530:ERROR>
Jan 27 10:13:42 com.google.Chrome.desktop[3711]: [59:59:0127/101342.156059:ERRO>
Jan 27 10:13:48 tailscaled[1281]: logtail: upload succeeded after 1 failures an>
Jan 27 10:13:53 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jan 27 10:13:53 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:13:53 audit: BPF prog-id=67 op=UNLOAD
Jan 27 10:13:57 realmd[1949]: quitting realmd service after timeout
Jan 27 10:13:57 realmd[1949]: stopping service
Jan 27 10:13:57 systemd[1]: realmd.service: Deactivated successfully.
Jan 27 10:13:57 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:14:05 com.google.Chrome.desktop[3577]: [2:42:0127/101405.717576:ERROR>
Jan 27 10:14:06 systemd[1]: systemd-localed.service: Deactivated successfully.
Jan 27 10:14:06 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:14:06 audit: BPF prog-id=72 op=UNLOAD
Jan 27 10:14:06 audit: BPF prog-id=71 op=UNLOAD
Jan 27 10:14:06 audit: BPF prog-id=70 op=UNLOAD
Jan 27 10:14:21 systemd[2252]: Starting gvfs-metadata.service - Virtual filesys>
Jan 27 10:14:21 systemd[2252]: Started gvfs-metadata.service - Virtual filesyst>
Jan 27 10:14:21 systemd[1]: rpm-ostreed.service: Deactivated successfully.
Jan 27 10:14:21 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:14:46 com.google.Chrome.desktop[3577]: [2:42:0127/101446.141110:ERROR>
Jan 27 10:16:18 systemd[2252]: Starting grub-boot-success.service - Mark boot a>
Jan 27 10:16:18 grub2-set-bootflag[4348]: Error canonicalizing /boot/grub2/grub>
Jan 27 10:16:18 systemd[2252]: grub-boot-success.service: Main process exited, >
Jan 27 10:16:18 systemd[2252]: grub-boot-success.service: Failed with result 'e>
Jan 27 10:16:18 systemd[2252]: Failed to start grub-boot-success.service - Mark>
Jan 27 10:16:37 com.google.Chrome.desktop[4379]: Warning: Old MapAsync APIs are>
Jan 27 10:16:42 com.google.Chrome.desktop[3577]: [2:42:0127/101642.168888:ERROR>
Jan 27 10:18:39 systemd[2252]: Created slice background.slice - User Background>
Jan 27 10:18:39 systemd[2252]: Starting podman-auto-update.service - Podman aut>
Jan 27 10:18:39 systemd[2252]: Starting systemd-tmpfiles-clean.service - Cleanu>
Jan 27 10:18:39 systemd[2252]: Finished systemd-tmpfiles-clean.service - Cleanu>
Jan 27 10:18:40 kernel: evm: overlay not supported
Jan 27 10:18:40 podman[4523]: 2025-01-27 10:18:40.261426804 -0500 EST m=+0.1585>
Jan 27 10:18:40 systemd[2252]: Created slice user.slice - Slice /user.
Jan 27 10:18:40 systemd[2252]: Started podman-pause-6a4bf977.scope.
Jan 27 10:18:40 systemd[2252]: Finished podman-auto-update.service - Podman aut>
Jan 27 10:18:40 systemd[2252]: podman-auto-update.service: Consumed 371ms CPU t>
Jan 27 10:19:31 chronyd[1087]: Selected source 23.186.168.2 (2.fedora.pool.ntp.>
Jan 27 10:19:44 com.google.Chrome.desktop[3577]: [2:42:0127/101944.274873:ERROR>
Jan 27 10:23:18 systemd[1]: Starting brew-update.service - Auto update brew for>
Jan 27 10:23:18 audit: BPF prog-id=75 op=LOAD
Jan 27 10:23:18 systemd[1]: Starting plocate-updatedb.service - Update the ploc>
Jan 27 10:23:19 bash[4792]: ==> Updating Homebrew…
Jan 27 10:23:22 bash[5111]: [43B blob data]
Jan 27 10:23:22 bash[5111]: Read the analytics documentation (and how to opt-ou>
Jan 27 10:23:22 bash[5111]: Anonymous Analytics — Homebrew Documentation
Jan 27 10:23:22 bash[5111]: No analytics have been recorded yet (nor will be du>
Jan 27 10:23:22 bash[5111]: ==> Homebrew is run entirely by unpaid volunteers. >
Jan 27 10:23:22 bash[5111]: GitHub - Homebrew/brew: 🍺 The missing package manager for macOS (or Linux)
Jan 27 10:23:23 bash[5111]: Updated 2 taps (homebrew/core and homebrew/cask).
Jan 27 10:23:23 bash[5111]: ==> New Formulae
Jan 27 10:23:23 bash[5111]: babelfish
Jan 27 10:23:23 bash[5111]: chiko
Jan 27 10:23:23 bash[5111]: precious
Jan 27 10:23:23 bash[5111]: sdl3
Jan 27 10:23:23 bash[5111]: ubi
Jan 27 10:23:23 systemd[1]: brew-update.service: Deactivated successfully.
Jan 27 10:23:23 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 10:23:23 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:23:23 systemd[1]: Finished brew-update.service - Auto update brew for>
Jan 27 10:23:23 systemd[1]: brew-update.service: Consumed 4.101s CPU time, 325M>
Jan 27 10:23:25 systemd[1]: plocate-updatedb.service: Deactivated successfully.
Jan 27 10:23:25 systemd[1]: Finished plocate-updatedb.service - Update the ploc>
Jan 27 10:23:25 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 10:23:25 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:23:25 systemd[1]: plocate-updatedb.service: Consumed 5.347s CPU time,>
Jan 27 10:23:25 audit: BPF prog-id=75 op=UNLOAD
Jan 27 10:23:28 gnome-shell[2570]: OpenWeather Refined: Failed to fetch weather>
Jan 27 10:23:28 gnome-shell[2570]: OpenWeather Refined: getWeatherInfo failed w>
Jan 27 10:27:13 com.google.Chrome.desktop[3577]: [2:42:0127/102713.463115:ERROR>
Jan 27 10:28:18 systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup o>
Jan 27 10:28:18 audit: BPF prog-id=76 op=LOAD
Jan 27 10:28:18 systemd[1]: Starting logrotate.service - Rotate log files…
Jan 27 10:28:18 audit[5815]: AVC avc: denied { getattr } for pid=5815 comm=“>
Jan 27 10:28:18 audit[5815]: AVC avc: denied { getattr } for pid=5815 comm=”>
Jan 27 10:28:18 logrotate[5815]: error: stat of /var/log/boot.log failed: Permi>
Jan 27 10:28:18 systemd[1]: logrotate.service: Main process exited, code=exited>
Jan 27 10:28:18 systemd[1]: logrotate.service: Failed with result ‘exit-code’.
Jan 27 10:28:18 systemd[1]: Failed to start logrotate.service - Rotate log file>
Jan 27 10:28:18 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 10:28:18 audit: BPF prog-id=76 op=UNLOAD
Jan 27 10:28:18 systemd[1]: systemd-tmpfiles-clean.service: Deactivated success>
Jan 27 10:28:18 systemd[1]: Finished systemd-tmpfiles-clean.service - Cleanup o>
Jan 27 10:28:18 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 10:28:18 systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dclean.servic>
Jan 27 10:28:36 systemd-logind[1097]: The system will suspend now!
Jan 27 10:28:36 ModemManager[1183]: [sleep-monitor-systemd] system is abo>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2034] manager: sleep:>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2040] manager: Networ>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2044] device (enp1s0f>
Jan 27 10:28:36 systemd[1]: Starting NetworkManager-dispatcher.service - Networ>
Jan 27 10:28:36 systemd[1]: Started NetworkManager-dispatcher.service - Network>
Jan 27 10:28:36 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2494] device (enp1s0f>
Jan 27 10:28:36 avahi-daemon[1060]: Withdrawing address record for fe80::6e4b:9>
Jan 27 10:28:36 avahi-daemon[1060]: Leaving mDNS multicast group on interface e>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2509] dhcp4 (enp1s0f0>
Jan 27 10:28:36 avahi-daemon[1060]: Interface enp1s0f0.IPv6 no longer relevant >
Jan 27 10:28:36 tailscaled[1281]: [RATELIMIT] format("monitor: %s: src=%v, dst=>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2513] dhcp4 (enp1s0f0>
Jan 27 10:28:36 tailscaled[1281]: monitor: RTM_DELROUTE: src=, dst=fe80::/64, g>
Jan 27 10:28:36 tailscaled[1281]: monitor: RTM_DELROUTE: src=, dst=fe80::6e4b:9>
Jan 27 10:28:36 tailscaled[1281]: monitor: RTM_DELROUTE: src=, dst=ff00::/8, gw>
Jan 27 10:28:36 avahi-daemon[1060]: Withdrawing address record for 192.168.50.1>
Jan 27 10:28:36 avahi-daemon[1060]: Interface enp1s0f0.IPv4 no longer relevant >
Jan 27 10:28:36 tailscaled[1281]: monitor: RTM_DELROUTE: src=192.168.50.141/0, >
Jan 27 10:28:36 tailscaled[1281]: [RATELIMIT] format(“monitor: %s: src=%v, dst=>
Jan 27 10:28:36 tailscaled[1281]: LinkChange: major, rebinding. New state: inte>
Jan 27 10:28:36 tailscaled[1281]: dns: Set: {DefaultResolvers: Routes:{} Sear>
Jan 27 10:28:36 tailscaled[1281]: dns: Resolvercfg: {Routes:{} Hosts:0 LocalDom>
Jan 27 10:28:36 tailscaled[1281]: dns: OScfg: {}
Jan 27 10:28:36 systemd-resolved[983]: enp1s0f0: Bus client set default route s>
Jan 27 10:28:36 systemd-resolved[983]: enp1s0f0: Bus client reset DNS server li>
Jan 27 10:28:36 NetworkManager[1220]: [1737991716.2690] device (enp1s0f>
Jan 27 10:28:36 kernel: r8169 0000:01:00.0 enp1s0f0: Link is Down
Jan 27 10:28:36 systemd-resolved[983]: Flushed all caches.
Jan 27 10:28:36 tailscaled[1281]: wgengine: set DNS config again after major li>
Jan 27 10:28:36 tailscaled[1281]: [RATELIMIT] format(“onPortUpdate(port=%v, net>
Jan 27 10:28:36 tailscaled[1281]: onPortUpdate(port=41641, network=udp6)
Jan 27 10:28:36 tailscaled[1281]: onPortUpdate(port=41641, network=udp4)
Jan 27 10:28:36 tailscaled[1281]: Rebind; defIf=””, ips=
Jan 27 10:28:36 tailscaled[1281]: magicsock: 0 active derp conns
Jan 27 10:28:36 audit[1184]: NETFILTER_CFG table=firewalld:20 family=1 entries=>
Jan 27 10:28:36 systemd[1]: Reached target sleep.target - Sleep.
Jan 27 10:28:36 systemd[1]: Starting systemd-suspend.service - System Suspend…
Jan 27 10:28:36 chronyd[1087]: Source 168.61.215.74 offline
Jan 27 10:28:36 chronyd[1087]: Source 108.61.73.244 offline
Jan 27 10:28:36 chronyd[1087]: Source 66.118.231.14 offline
Jan 27 10:28:36 chronyd[1087]: Can’t synchronise: no selectable sources
Jan 27 10:28:36 systemd-sleep[5880]: User sessions remain unfrozen on explicit >
Jan 27 10:28:36 chronyd[1087]: Source 23.186.168.2 offline
Jan 27 10:28:36 systemd-sleep[5880]: This is not recommended, and might result >
Jan 27 10:28:36 systemd-sleep[5880]: in suspend-then-hibernate operations or se>
Jan 27 10:28:36 systemd-sleep[5880]: Performing sleep operation ‘suspend’…
Jan 27 10:28:36 kernel: PM: suspend entry (deep)
It just did it again:
Jan 27 12:20:05 systemd[2221]: Starting flatpak-session-helper.service - flatpa>
Jan 27 12:20:05 systemd[2221]: Started flatpak-session-helper.service - flatpak>
Jan 27 12:20:05 systemd[2221]: Started app-flatpak-org.gnome.NautilusPreviewer->
Jan 27 12:20:05 systemd[2221]: Started tracker-miner-fs-3.service - Tracker fil>
Jan 27 12:20:05 systemd[1]: bluetooth.service - Bluetooth service was skipped b>
Jan 27 12:20:06 udisksd[1061]: Mounted /dev/sda3 at /run/media/root/7C6C-5F3E o>
Jan 27 12:20:06 systemd[1]: run-media-root-7C6C\x2d5F3E.mount: Deactivated succ>
Jan 27 12:20:06 udisksd[1061]: Cleaning up mount point /run/media/root/7C6C-5F3>
Jan 27 12:20:06 udisksd[1061]: Unmounted /dev/sda3 on behalf of uid 0
Jan 27 12:20:06 audit: BPF prog-id=74 op=LOAD
Jan 27 12:20:06 systemd[1]: Starting passim.service - Local Caching Server…
Jan 27 12:20:06 avahi-daemon[1030]: Missed message org.freedesktop.DBus.Propert>
Jan 27 12:20:06 systemd[1]: Started passim.service - Local Caching Server.
Jan 27 12:20:06 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 12:20:06 fwupd[3306]: 17:20:06.884 FuMain Daemon ready for>
Jan 27 12:20:06 systemd[1]: Started fwupd.service - Firmware update daemon.
Jan 27 12:20:08 gnome-shell[2531]: GNOME Shell started at Mon Jan 27 2025 12:20>
Jan 27 12:20:08 gnome-shell[2531]: Registering session with GDM
Jan 27 12:20:08 gnome-shell[1413]: Connection to xwayland lost
Jan 27 12:20:08 gnome-shell[1413]: Xwayland terminated, exiting since it was ma>
Jan 27 12:20:08 gnome-shell[1413]: (…/src/core/meta-context.c:597):meta_contex>
Jan 27 12:20:08 gnome-shell[1413]: JS ERROR: Gio.IOErrorEnum: Xwayland exited u>
@resource:///org/gnome/shell/ui/init.js:21:20
Jan 27 12:20:08 gnome-shell[1413]: Execution of main.js threw exception: Module>
Jan 27 12:20:08 cupsd[1226]: REQUEST localhost - - “POST / HTTP/1.1” 200 151 Ca>
Jan 27 12:20:08 gdm-launch-environment][1320]: pam_unix(gdm-launch-environment:>
Jan 27 12:20:08 audit[1320]: USER_END pid=1320 uid=0 auid=4294967295 ses=429496>
Jan 27 12:20:08 audit[1320]: CRED_DISP pid=1320 uid=0 auid=4294967295 ses=42949>
Jan 27 12:20:08 xdg-document-po[2145]: Error releasing name org.freedesktop.por>
Jan 27 12:20:08 /usr/libexec/gdm-wayland-session[1541]: Failed to launch bus: B>
Jan 27 12:20:08 systemd[1]: run-user-42-doc.mount: Deactivated successfully.
Jan 27 12:20:08 systemd-logind[1058]: Session c1 logged out. Waiting for proces>
Jan 27 12:20:08 systemd[1]: session-c1.scope: Deactivated successfully.
Jan 27 12:20:08 systemd[1]: session-c1.scope: Consumed 7.445s CPU time, 578.6M >
Jan 27 12:20:08 systemd-logind[1058]: Removed session c1.
Jan 27 12:20:08 gdm[1293]: Gdm: Child process -1381 was already dead.
Jan 27 12:20:08 gnome-shell[2531]: OpenWeather Refined: Failed to fetch weather>
Jan 27 12:20:08 gnome-shell[2531]: OpenWeather Refined: getWeatherInfo failed w>
Jan 27 12:20:12 systemd[2221]: Started dbus-:1.2-org.gnome.Ptyxis@0.service.
Jan 27 12:20:12 gnome-software[2778]: Tried to set invalid release date: YYYY-M>
Jan 27 12:20:12 kernel: evm: overlay not supported
Jan 27 12:20:12 podman[3535]: 2025-01-27 12:20:12.719145111 -0500 EST m=+0.1477>
Jan 27 12:20:12 systemd[2221]: Created slice user.slice - Slice /user.
Jan 27 12:20:12 systemd[2221]: Started podman-pause-add519db.scope.
Jan 27 12:20:13 systemd[2221]: Started run-r5d4182c783df408191d148eee8c0aa82.sc>
Jan 27 12:20:13 rpm-ostree[2347]: Allowing active client :1.153 (uid 1000)
Jan 27 12:20:13 rpm-ostree[2347]: client(id:cli dbus:1.153 unit:run-r5d4182c783>
Jan 27 12:20:13 rpm-ostree[2347]: In idle state; will auto-exit in 60 seconds
Jan 27 12:20:15 gnome-software[2778]: Tried to set invalid release date: YYYY-M>
Jan 27 12:20:15 nautilus[3201]: GSConnect: [Errno 2] No translation file found >
Jan 27 12:20:15 nautilus[3201]: open-any-terminal: terminal is set to “ptyxis” >
Jan 27 12:20:16 systemd[1]: fprintd.service: Deactivated successfully.
Jan 27 12:20:16 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:20:16 audit: BPF prog-id=73 op=UNLOAD
Jan 27 12:20:17 systemd[2221]: app-flatpak-org.gnome.NautilusPreviewer-3313.sco>
Jan 27 12:20:18 gnome-software[2778]: Tried to set invalid release date: YYYY-M>
Jan 27 12:20:18 systemd[1]: Stopping user@42.service - User Manager for UID 42.>
Jan 27 12:20:18 systemd[1353]: Activating special unit exit.target…
Jan 27 12:20:18 systemd[1353]: Stopped target default.target - Main User Target.
Jan 27 12:20:18 systemd[1353]: Stopping mpris-proxy.service - Bluetooth mpris p>
Jan 27 12:20:18 systemd[1353]: Stopping pipewire-pulse.service - PipeWire Pulse>
Jan 27 12:20:18 systemd[1353]: Stopped mpris-proxy.service - Bluetooth mpris pr>
Jan 27 12:20:18 systemd[1353]: Stopped pipewire-pulse.service - PipeWire PulseA>
Jan 27 12:20:18 systemd[1353]: Stopping wireplumber.service - Multimedia Servic>
Jan 27 12:20:18 wireplumber[1922]: wireplumber: stopped by signal: Terminated
Jan 27 12:20:18 wireplumber[1922]: wireplumber: disconnected from pipewire
Jan 27 12:20:18 systemd[1353]: Stopped wireplumber.service - Multimedia Service>
Jan 27 12:20:18 systemd[1353]: Stopping pipewire.service - PipeWire Multimedia >
Jan 27 12:20:18 systemd[1353]: Stopped pipewire.service - PipeWire Multimedia S>
Jan 27 12:20:18 systemd[1353]: Stopped target basic.target - Basic System.
Jan 27 12:20:18 systemd[1353]: Stopped target paths.target - Paths.
Jan 27 12:20:18 systemd[1353]: Stopped target sockets.target - Sockets.
Jan 27 12:20:18 systemd[1353]: Stopped target timers.target - Timers.
Jan 27 12:20:18 systemd[1353]: Stopped podman-auto-update.timer - Podman auto-u>
Jan 27 12:20:18 systemd[1353]: Stopped systemd-tmpfiles-clean.timer - Daily Cle>
Jan 27 12:20:18 systemd[1353]: Closed pipewire-pulse.socket - PipeWire PulseAud>
Jan 27 12:20:18 systemd[1353]: Closed pipewire.socket - PipeWire Multimedia Sys>
Jan 27 12:20:18 dbus-broker[1394]: Dispatched 468 messages @ 8(±62)μs / message.
Jan 27 12:20:18 systemd[1353]: Stopping dbus-broker.service - D-Bus User Messag>
Jan 27 12:20:18 systemd[1353]: Stopped systemd-tmpfiles-setup.service - Create >
Jan 27 12:20:18 systemd[1353]: Stopped dbus-broker.service - D-Bus User Message>
Jan 27 12:20:18 systemd[1353]: Removed slice session.slice - User Core Session >
Jan 27 12:20:18 systemd[1353]: Closed dbus.socket - D-Bus User Message Bus Sock>
Jan 27 12:20:18 systemd[1353]: Removed slice app.slice - User Application Slice.
Jan 27 12:20:18 systemd[1353]: Reached target shutdown.target - Shutdown.
Jan 27 12:20:18 systemd[1353]: Finished systemd-exit.service - Exit the Session.
Jan 27 12:20:18 systemd[1353]: Reached target exit.target - Exit the Session.
Jan 27 12:20:18 systemd[1]: user@42.service: Deactivated successfully.
Jan 27 12:20:18 systemd[1]: Stopped user@42.service - User Manager for UID 42.
Jan 27 12:20:18 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:20:18 systemd[1]: user@42.service: Consumed 1.179s CPU time, 36.4M me>
Jan 27 12:20:18 systemd[1]: Stopping user-runtime-dir@42.service - User Runtime>
Jan 27 12:20:18 systemd[1]: run-user-42.mount: Deactivated successfully.
Jan 27 12:20:18 systemd[1]: user-runtime-dir@42.service: Deactivated successful>
Jan 27 12:20:18 systemd[1]: Stopped user-runtime-dir@42.service - User Runtime >
Jan 27 12:20:18 systemd[1]: Removed slice user-42.slice - User Slice of UID 42.
Jan 27 12:20:18 systemd[1]: user-42.slice: Consumed 8.667s CPU time, 614.6M mem>
Jan 27 12:20:18 systemd-logind[1058]: Removed session 1.
Jan 27 12:20:34 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jan 27 12:20:34 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:20:34 audit: BPF prog-id=67 op=UNLOAD
Jan 27 12:20:35 tailscaled[1240]: logtail: upload succeeded after 1 failures an>
Jan 27 12:20:42 audit: BPF prog-id=75 op=LOAD
Jan 27 12:20:42 systemd[1]: Starting fprintd.service - Fingerprint Authenticati>
Jan 27 12:20:42 systemd[1]: Started fprintd.service - Fingerprint Authenticatio>
Jan 27 12:20:42 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 12:20:45 audit[3981]: USER_AUTH pid=3981 uid=1000 auid=1000 ses=3 subj=u>
Jan 27 12:20:45 audit[3981]: USER_ACCT pid=3981 uid=1000 auid=1000 ses=3 subj=u>
Jan 27 12:20:45 sudo[3981]: droffice : TTY=pts/0 ; PWD=/usr/share/ublue-os ; US>
Jan 27 12:20:45 audit[3981]: USER_CMD pid=3981 uid=1000 auid=1000 ses=3 subj=un>
Jan 27 12:20:45 audit[3981]: CRED_REFR pid=3981 uid=1000 auid=1000 ses=3 subj=u>
Jan 27 12:20:45 systemd-logind[1058]: Existing logind session ID 3 used by new >
Jan 27 12:20:45 systemd-logind[1058]: New session c2 of user root.
Jan 27 12:20:45 systemd[1]: Created slice user-0.slice - User Slice of UID 0.
Jan 27 12:20:45 systemd[1]: Starting user-runtime-dir@0.service - User Runtime >
Jan 27 12:20:45 systemd[1]: Finished user-runtime-dir@0.service - User Runtime >
Jan 27 12:20:45 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 12:20:45 systemd[1]: Starting user@0.service - User Manager for UID 0…
Jan 27 12:20:45 audit[3995]: USER_ACCT pid=3995 uid=0 auid=4294967295 ses=42949>
Jan 27 12:20:45 audit[3995]: CRED_ACQ pid=3995 uid=0 auid=4294967295 ses=429496>
Jan 27 12:20:45 audit[3995]: USER_ROLE_CHANGE pid=3995 uid=0 auid=4294967295 se>
Jan 27 12:20:45 systemd-logind[1058]: New session 4 of user root.
Jan 27 12:20:45 (systemd)[3995]: pam_unix(systemd-user:session): session opened>
Jan 27 12:20:45 audit[3995]: USER_START pid=3995 uid=0 auid=0 ses=4 subj=system>
Jan 27 12:20:45 audit: BPF prog-id=76 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=76 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=77 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=77 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=78 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=78 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=79 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=79 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=80 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=80 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=81 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=81 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=82 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=82 op=UNLOAD
Jan 27 12:20:45 uresourced[1343]: Setting resources on user-0.slice (MemoryMin:>
Jan 27 12:20:45 uresourced[1343]: Setting resources on user@0.service (MemoryMi>
Jan 27 12:20:45 audit: BPF prog-id=83 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=84 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=83 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=84 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=85 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=85 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=86 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=86 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=87 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=87 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=88 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=88 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=89 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=90 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=90 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=91 op=LOAD
Jan 27 12:20:45 audit: BPF prog-id=89 op=UNLOAD
Jan 27 12:20:45 audit: BPF prog-id=91 op=UNLOAD
Jan 27 12:20:45 systemd[3995]: Queued start job for default target default.targ>
Jan 27 12:20:45 systemd[3995]: Created slice app.slice - User Application Slice.
Jan 27 12:20:45 systemd[3995]: grub-boot-success.timer - Mark boot as successfu>
Jan 27 12:20:45 systemd[3995]: Started podman-auto-update.timer - Podman auto-u>
Jan 27 12:20:45 systemd[3995]: Started systemd-tmpfiles-clean.timer - Daily Cle>
Jan 27 12:20:45 systemd[3995]: Reached target paths.target - Paths.
Jan 27 12:20:45 systemd[3995]: Reached target timers.target - Timers.
Jan 27 12:20:45 systemd[3995]: Starting dbus.socket - D-Bus User Message Bus So>
Jan 27 12:20:45 systemd[3995]: pipewire-pulse.socket - PipeWire PulseAudio was >
Jan 27 12:20:45 systemd[3995]: Listening on pipewire.socket - PipeWire Multimed>
Jan 27 12:20:45 systemd[3995]: Starting systemd-tmpfiles-setup.service - Create>
Jan 27 12:20:45 systemd[3995]: Finished systemd-tmpfiles-setup.service - Create>
Jan 27 12:20:45 systemd[3995]: Listening on dbus.socket - D-Bus User Message Bu>
Jan 27 12:20:45 systemd[3995]: Reached target sockets.target - Sockets.
Jan 27 12:20:45 systemd[3995]: Reached target basic.target - Basic System.
Jan 27 12:20:45 systemd[3995]: gnome-initial-setup-copy-worker.service - GNOME >
Jan 27 12:20:45 systemd[1]: Started user@0.service - User Manager for UID 0.
Jan 27 12:20:45 systemd[3995]: Started mpris-proxy.service - Bluetooth mpris pr>
Jan 27 12:20:45 systemd[3995]: Starting ublue-flatpak-manager.service - Manage >
Jan 27 12:20:45 systemd[1]: Started session-c2.scope - Session c2 of User root.
Jan 27 12:20:45 systemd[3995]: Started ublue-user-setup.service - Configure sys>
Jan 27 12:20:45 sudo[3981]: pam_unix(sudo:session): session opened for user roo>
Jan 27 12:20:45 audit[3981]: USER_START pid=3981 uid=1000 auid=1000 ses=3 subj=>
Jan 27 12:20:45 systemd[3995]: Created slice session.slice - User Core Session >
Jan 27 12:20:45 ublue-flatpak-manager[4027]: Flatpak manager v2 has already ran>
Jan 27 12:20:45 systemd[3995]: Starting dbus-broker.service - D-Bus User Messag>
Jan 27 12:20:45 systemd[3995]: Finished ublue-flatpak-manager.service - Manage >
Jan 27 12:20:45 systemd[3995]: Reached target default.target - Main User Target.
Jan 27 12:20:45 ublue-user-setup[4040]: /root/.local/share/ublue
Jan 27 12:20:45 ublue-user-setup[4028]: User setup v has already run. Exiting…
Jan 27 12:20:45 dbus-broker-launch[4035]: Policy to allow eavesdropping in /usr>
Jan 27 12:20:45 systemd[3995]: Started dbus-broker.service - D-Bus User Message>
Jan 27 12:20:45 systemd[3995]: Startup finished in 424ms.
Jan 27 12:20:45 dbus-broker-launch[4035]: Ready
Jan 27 12:20:46 systemd[1]: systemd-localed.service: Deactivated successfully.
Jan 27 12:20:46 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:20:46 audit: BPF prog-id=72 op=UNLOAD
Jan 27 12:20:46 audit: BPF prog-id=71 op=UNLOAD
Jan 27 12:20:46 audit: BPF prog-id=70 op=UNLOAD
Jan 27 12:20:47 realmd[1997]: quitting realmd service after timeout
Jan 27 12:20:47 realmd[1997]: stopping service
Jan 27 12:20:47 systemd[1]: realmd.service: Deactivated successfully.
Jan 27 12:20:47 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:21:02 systemd[2221]: Starting gvfs-metadata.service - Virtual filesys>
Jan 27 12:21:02 systemd[2221]: Started gvfs-metadata.service - Virtual filesyst>
Jan 27 12:21:13 rpm-ostree[2347]: In idle state; will auto-exit in 63 seconds
Jan 27 12:21:13 systemd[1]: fprintd.service: Deactivated successfully.
Jan 27 12:21:13 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:21:13 audit: BPF prog-id=75 op=UNLOAD
Jan 27 12:21:13 systemd[1]: rpm-ostreed.service: Deactivated successfully.
Jan 27 12:22:22 systemd[2221]: Starting grub-boot-success.service - Mark boot a>
Jan 27 12:22:22 grub2-set-bootflag[4472]: Error canonicalizing /boot/grub2/grub>
Jan 27 12:22:22 systemd[2221]: grub-boot-success.service: Main process exited, >
Jan 27 12:22:22 systemd[2221]: grub-boot-success.service: Failed with result 'e>
Jan 27 12:22:22 systemd[2221]: Failed to start grub-boot-success.service - Mark>
Jan 27 12:23:53 systemd[3995]: Starting podman-auto-update.service - Podman aut>
Jan 27 12:23:53 systemd[1]: var-lib-containers-storage-overlay-compat781958285->
Jan 27 12:23:53 podman[4860]: 2025-01-27 12:23:53.704124048 -0500 EST m=+0.0991>
Jan 27 12:23:53 systemd[3995]: Finished podman-auto-update.service - Podman aut>
Jan 27 12:23:54 systemd[1]: var-lib-containers-storage-overlay.mount: Deactivat>
Jan 27 12:25:22 systemd[2221]: Created slice background.slice - User Background>
Jan 27 12:25:22 systemd[2221]: Starting systemd-tmpfiles-clean.service - Cleanu>
Jan 27 12:25:22 systemd[2221]: Finished systemd-tmpfiles-clean.service - Cleanu>
Jan 27 12:25:50 systemd[2221]: Started app-gnome-com.google.Chrome-5395.scope →
Jan 27 12:25:50 systemd[2221]: Started app-flatpak-com.google.Chrome-5395.scope.
Jan 27 12:25:51 systemd[2221]: Reached target gnome-session-x11-services.target>
Jan 27 12:25:51 systemd[2221]: Starting org.gnome.SettingsDaemon.XSettings.serv>
Jan 27 12:25:51 gnome-shell[5430]: The XKEYBOARD keymap compiler (xkbcomp) repo>
Jan 27 12:25:51 gnome-shell[5430]: > Warning: Unsupported maximum keyc>
Jan 27 12:25:51 gnome-shell[5430]: > X11 cannot support keyco>
Jan 27 12:25:51 gnome-shell[5430]: > Warning: Could not resolve keysym>
Jan 27 12:25:51 gnome-shell[5430]: Errors from xkbcomp are not fatal to the X s>
Jan 27 12:25:51 gsd-xsettings[5431]: Failed to get current UI scaling factor: G>
Jan 27 12:25:51 systemd[2221]: Started org.gnome.SettingsDaemon.XSettings.servi>
Jan 27 12:25:51 systemd[2221]: Reached target gnome-session-x11-services-ready.>
Jan 27 12:25:51 cobalt[5413]: Failed to load module “canberra-gtk-module”
Jan 27 12:25:51 systemd[2221]: Starting flatpak-portal.service - flatpak portal>
Jan 27 12:25:51 systemd[2221]: Started flatpak-portal.service - flatpak portal.
Jan 27 12:25:51 mutter-x11-fram[5459]: Using GtkSettings:gtk-application-prefer>
Jan 27 12:25:51 com.google.Chrome.desktop[5413]: [0127/122551.656200:WARNING:ch>
Jan 27 12:25:52 systemd[2221]: Started app-flatpak-com.google.Chrome-5516.scope.
Jan 27 12:25:52 com.google.Chrome.desktop[5514]: [0127/122552.439079:WARNING:ch>
Jan 27 12:25:52 chrome[5413]: Failed to load module “canberra-gtk-module”
Jan 27 12:25:52 systemd[1]: bluetooth.service - Bluetooth service was skipped b>
Jan 27 12:25:52 gnome-keyring-daemon[2255]: asked to register item /org/freedes>
Jan 27 12:25:53 com.google.Chrome.desktop[5413]: [2:2:0127/122553.292781:ERROR:>
Jan 27 12:25:55 gnome-shell[2531]: Can’t update stage views actor dashtodockCon>
Jan 27 12:25:55 gnome-shell[2531]: Can’t update stage views actor unnamed [Gjs_>
Jan 27 12:25:55 gnome-shell[2531]: Can’t update stage views actor dashtodockBox>
Jan 27 12:25:55 gnome-shell[2531]: Can’t update stage views actor bms-dash-back>
Jan 27 12:25:55 gnome-shell[2531]: Can’t update stage views actor bms-dash-blur>
Jan 27 12:25:55 systemd[2221]: Started app-flatpak-com.google.Chrome-5957.scope.
Jan 27 12:25:55 com.google.Chrome.desktop[5413]: Created TensorFlow Lite XNNPAC>
Jan 27 12:25:55 com.google.Chrome.desktop[5413]: Attempting to use a delegate t>
Jan 27 12:25:56 com.google.Chrome.desktop[5413]: [2:42:0127/122556.009464:ERROR>
Jan 27 12:25:57 com.google.Chrome.desktop[5413]: [2:2:0127/122557.977398:ERROR:>
Jan 27 12:26:17 com.google.Chrome.desktop[5413]: [2:42:0127/122617.370850:ERROR>
Jan 27 12:26:22 systemd[3995]: Created slice background.slice - User Background>
Jan 27 12:26:22 systemd[3995]: Starting systemd-tmpfiles-clean.service - Cleanu>
Jan 27 12:26:22 systemd[3995]: Finished systemd-tmpfiles-clean.service - Cleanu>
Jan 27 12:26:58 com.google.Chrome.desktop[5413]: [2:42:0127/122658.990486:ERROR>
Jan 27 12:27:03 com.google.Chrome.desktop[5558]: [59:59:0127/122703.930529:ERRO>
Jan 27 12:27:34 com.google.Chrome.desktop[5558]: [59:59:0127/122734.819856:ERRO>
Jan 27 12:27:37 com.google.Chrome.desktop[5558]: [59:59:0127/122737.115117:ERRO>
Jan 27 12:28:11 gnome-shell[2531]: Can’t update stage views actor dashtodockCon>
Jan 27 12:28:11 gnome-shell[2531]: Can’t update stage views actor unnamed [Gjs_>
Jan 27 12:28:11 gnome-shell[2531]: Can’t update stage views actor dashtodockBox>
Jan 27 12:28:11 gnome-shell[2531]: Can’t update stage views actor bms-dash-back>
Jan 27 12:28:11 gnome-shell[2531]: Can’t update stage views actor bms-dash-blur>
Jan 27 12:28:20 gnome-shell[2531]: Can’t update stage views actor dashtodockCon>
Jan 27 12:28:20 gnome-shell[2531]: Can’t update stage views actor unnamed [Gjs_>
Jan 27 12:28:20 gnome-shell[2531]: Can’t update stage views actor dashtodockBox>
Jan 27 12:28:20 gnome-shell[2531]: Can’t update stage views actor bms-dash-back>
Jan 27 12:28:20 gnome-shell[2531]: Can’t update stage views actor bms-dash-blur>
Jan 27 12:28:31 com.google.Chrome.desktop[5413]: [2:42:0127/122831.704413:ERROR>
Jan 27 12:28:31 gnome-shell[2531]: Called enable_unredirect_for_display while u>
Jan 27 12:28:52 com.google.Chrome.desktop[7829]: Warning: Old MapAsync APIs are>
Jan 27 12:30:08 com.google.Chrome.desktop[5563]: [64:71:0127/123008.577054:ERRO>
Jan 27 12:30:08 com.google.Chrome.desktop[5563]: [64:71:0127/123008.609889:ERRO>
Jan 27 12:30:08 com.google.Chrome.desktop[5563]: [64:71:0127/123008.609936:ERRO>
Jan 27 12:30:08 com.google.Chrome.desktop[5514]: [1642:1240:0127/123008.659324:>
Jan 27 12:30:08 gnome-shell[2531]: OpenWeather Refined: Failed to fetch weather>
Jan 27 12:30:08 gnome-shell[2531]: OpenWeather Refined: getWeatherInfo failed w>
Jan 27 12:30:09 com.google.Chrome.desktop[5563]: [64:71:0127/123009.602068:ERRO>
Jan 27 12:30:09 com.google.Chrome.desktop[5563]: [64:71:0127/123009.602189:ERRO>
Jan 27 12:30:09 com.google.Chrome.desktop[5563]: [64:71:0127/123009.603612:ERRO>
Jan 27 12:30:10 com.google.Chrome.desktop[5514]: [1642:1240:0127/123010.615137:>
Jan 27 12:30:18 com.google.Chrome.desktop[5514]: [1642:1240:0127/123018.731682:>
Jan 27 12:30:20 com.google.Chrome.desktop[5514]: [1642:1240:0127/123020.686063:>
Jan 27 12:30:22 systemd[1]: Starting brew-update.service - Auto update brew for>
Jan 27 12:30:22 bash[8582]: ==> Updating Homebrew…
Jan 27 12:30:25 bash[8901]: [43B blob data]
Jan 27 12:30:25 bash[8901]: Read the analytics documentation (and how to opt-ou>
Jan 27 12:30:25 bash[8901]: Anonymous Analytics — Homebrew Documentation
Jan 27 12:30:25 bash[8901]: No analytics have been recorded yet (nor will be du>
Jan 27 12:30:25 bash[8901]: ==> Homebrew is run entirely by unpaid volunteers. >
Jan 27 12:30:25 bash[8901]: GitHub - Homebrew/brew: 🍺 The missing package manager for macOS (or Linux)
Jan 27 12:30:26 bash[8901]: Already up-to-date.
Jan 27 12:30:27 systemd[1]: brew-update.service: Deactivated successfully.
Jan 27 12:30:27 systemd[1]: Finished brew-update.service - Auto update brew for>
Jan 27 12:30:27 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 27 12:30:27 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 27 12:30:27 systemd[1]: brew-update.service: Consumed 4.112s CPU time, 323.>
Jan 27 12:30:28 com.google.Chrome.desktop[5514]: [1642:1240:0127/123028.810212:>
Jan 27 12:30:30 com.google.Chrome.desktop[5514]: [1642:1240:0127/123030.763140:>
Jan 27 12:30:38 com.google.Chrome.desktop[5514]: [1642:1240:0127/123038.889469:>
Jan 27 12:30:40 com.google.Chrome.desktop[5514]: [1642:1240:0127/123040.843281:>
Jan 27 12:30:48 com.google.Chrome.desktop[5514]: [1642:1240:0127/123048.967239:>
Jan 27 12:30:50 com.google.Chrome.desktop[5514]: [1642:1240:0127/123050.921707:>
Jan 27 12:30:59 com.google.Chrome.desktop[5514]: [1642:1240:0127/123059.045678:>
Jan 27 12:31:01 com.google.Chrome.desktop[5514]: [1642:1240:0127/123101.014363:>
Jan 27 12:32:25 com.google.Chrome.desktop[5413]: [2:42:0127/123225.235842:ERROR>
Jan 27 12:35:22 systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup o>
lines 3092-3114/3114 (END)
I noticed this in the log, which seems to be trying to put the system to sleep. I tried running that service on my own laptop and it immediately froze, so that’s probably it.
I’m not sure how systemd-suspend.service works but I would start investigating that and see how you can disable it.
I turned off Automatic Suspend in the settings, and while hopeful, it just froze again.
I reinstalled bluefin yesterday evening before going home. It was working all day today and then it just froze again.
Blockquote…skipping…
Jan 31 15:40:36 systemd[1]: Finished sysstat-collect.service - system activity >
Jan 31 15:40:36 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967>
Jan 31 15:40:36 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=42949672>
Jan 31 15:41:24 com.google.Chrome.desktop[4798]: [2:2:0131/154124.708493:ERROR:>
Jan 31 15:41:24 com.google.Chrome.desktop[4798]: [2:2:0131/154124.710806:ERROR:>
Jan 31 15:44:24 com.google.Chrome.desktop[4926]: [59:59:0131/154424.959787:ERRO>
Jan 31 15:44:37 pipewire[3687]: pw.node: (alsa_output.pci-0000_03_00.6.analog-s>
Jan 31 15:45:11 com.google.Chrome.desktop[4926]: [59:59:0131/154511.241617:ERRO>
Jan 31 15:46:13 kernel: amdgpu 0000:03:00.0: amdgpu: Dumping IP State
Jan 31 15:46:14 gnome-shell[3720]: libinput error: client bug: timer event3 deb>
Jan 31 15:46:17 com.google.Chrome.desktop[4819]: [0131/154617.398249:ERROR:scop>
Jan 31 15:46:43 systemd-logind[1199]: Power key pressed short.
Jan 31 15:46:43 gnome-shell[3720]: No listeners 187
Jan 31 15:46:44 gnome-shell[3720]: endSessionDialog: No XDG_SESSION_ID, fetched>
Jan 31 15:46:46 kernel: watchdog: BUG: soft lockup - CPU#2 stuck for 26s! [kwor>
Jan 31 15:46:46 kernel: CPU#2 Utilization every 4s during lockup:
Jan 31 15:46:46 kernel: #1: 2% system, 0% softirq, >
Jan 31 15:46:46 kernel: #2: 2% system, 0% softirq, >
Jan 31 15:46:46 kernel: #3: 2% system, 0% softirq, >
Jan 31 15:46:46 kernel: #4: 2% system, 0% softirq, >
Jan 31 15:46:46 kernel: #5: 2% system, 0% softirq, >
error: Recipe logs-last-boot was terminated on line 21 by signal 2
@jankdc I had the same problem with Aurora-DX on Asus with AMD + Vega. It would freeze constantly on kernel 6.12, and rarely on 6.11.
I had success with these options:
  • Going back to an early 6.11 build - November or earlier
  • Using the most recent builds from the last week (kernel 6.12.12), and testing out different combinations of:
    • Refresh rate (60Hz worked for me)
    • Adaptive sync (“Always” worked for me)
I have had no crashes for the last 5 days with 6.12.12 + 60Hz + Always.
Unfortunately we don’t yet have 6.12.12 kernel on Aurora or Bluefin. Its still in Fedoras testing repos.
Only HWE images (like Asus and Surface) and Bazzite have that kernel version as the Bazzite kernel is a separate and custom kernel.
https://bodhi.fedoraproject.org/updates/FEDORA-2025-d00af34217
I’m using it on Aurora right now…?
https://github.com/ublue-os/bluefin/pkgs/container/aurora-dx-hwe/351819072?tag=latest
If there’s no reason it wouldn’t work on Lenovo, it might be worth trying.
Yes you are on HWE (aurora-dx-hwe) image, which uses Bazzite kernel.
EDIT: Anything with a -hwe suffix will use the Bazzite kernel and it moves faster than the stock fedora kernel that main images of Aurora/Bluefin uses.
