I tried Bluefin again today, and it froze again. So it’s not fixable on Bluefin right now? Does Bluefin have a version with the Bazzite kernel?
Yes - bluefin-hwe, or bluefin-dx-hwe if you want the developer version.
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-hwe:latest
I’m going to try this. Should I switch back to the regular kernel at some point?
If it works it works. I’ve been using -hwe (previously -asus, but I think they’re the same?) for a year without any issues.
You could switch back to stable once the kernel in that gets updated.
Well, it didn’t work. It froze on -hwe.
At this point I feel like you’d probably want to give up, but if you want to persist, did do the other important point from my earlier post? This part was critical for me:
- Using the
hwe:latestimage, and testing out different combinations of:- Refresh rate (60Hz worked for me)
- Adaptive sync (“Always” worked for me)
And did you try this one?
- Going back to a build before November (i.e. keep going back in time month-by-month until you find something stable)
You can find all the images here: Package bluefin · GitHub
No doubt there’s a way to actually troubleshoot this and discover the root cause, but I don’t have the skill for that so I’m just sharing what bypassed the issue for me.
I’m not going to go back to older builds. I have the refresh rate at 60Hz, but I can’t find the setting for Adaptive sync. Where would I find this?
Thanks
Hi there,
I have a similar issue with bluefin-dx-nvidia:stable. it imo started after setting up my Librewolf for hw acceleration and enabling VRR in Gnome.
I’m currently trying MOZ_ENABLE_WAYLAND=0, because I’ve set this to 1 for the hw acceleration.
ujust logs-last-boot gives me:
Mär 05 13:46:27 kernel: nvidia-modeset: ERROR: GPU:0: Error while waiting for GPU progress: 0x0000c77d:0 5:0:3620:3600
You can enbale VRR with:
gsettings set org.gnome.mutter experimental-features “[‘variable-refresh-rate’,‘scale-monitor-framebuffer’]”
maybe needs sudo.
I tried again last week, and it looks like everything is working. I booted into Bluefin and updated it, and it hasn’t frozen in a week. I’m on—hwe.
Same here.
Looks like disabling VRR worked in the end. But can’t say for sure it was the fix. Some updates were installed too.
