Blackscreen in gamescoop
hi every one I downloaded bazzite for Asus laptops with AMD GPU with game mode
but I get black screen some says in game mode because of the iGPU and dGPU the system cant choose one
so is there a fix in the future for it and if I install it without game mode can I upgrade to the gamemode in the future ?
mine is
AMD Advantege
GPU RX 6800m
CPU R9 59850HX
Hi, I’m not entirely sure since I never had an iGPU + dGPU setup. Though it is AMD Advantage, so it shouldn’t be any issues – the only iGPU + dGPU setup that I’ve heard issues with Have you tried running with ScopeBuddy:
Also, are you trying to run MangoHud as well? That has known issues by default, which scb works around automatically.
Edit: Now that I read it closelier, it seems the issue is with Game Mode? And, switching between image with game mode and without game mode should be fine as long as you’re not switching between desktop environment (no GNOME to KDE or vice versa – can confirm this breaks things).
