From the time I install bazzite-deck until now gaming mode doesn’t work and I get a black screen on boot. I can login to plasma desktop bay “steamos-session-select plasma” from tty2 but every time need to also re-login to steam account.
I’m using also archlinux and recently I tried to login to a steamos session and I found that I have quite the same issue there too. Also found that the problem caused by the new gamescope versions and after I downgrade gamescope to version 0.3.19 I manage to successfully login and use steam gaming mode.
So, I’m asking here if is possible and how to downgrade gamescope to this version so to, hopefully, be able to use gaming mode.
