Best way to install a Keyboard layout
Hi everybody,
I am trying to install this keyboard layout in bazzite: GitHub - qwerty-fr/qwerty-fr: Qwerty keyboard layout with French accents
If I follow the documentation, I guess I should use this installation method: GitHub - qwerty-fr/qwerty-fr: Qwerty keyboard layout with French accents
Though, I have the feeling this would against the atomicity of Bazzite/Bluefin.
What would be the best way to install this layout?
If someone comes across this post this is what I followed to install the layout:
rpm-ostree install alien
sudo alien -r qwerty-fr_0.7.3_linux.deb  --scripts
rpm-ostree install xkb-qwerty-fr-0.7.3-2.noarch.rpm
Thanks a lot for sharing your solution, it worked perfectly
