Hi all,
so please bare with me, as this is my first Fedora-based distro, my first atomic one and also the first time I’m using KDE. So this maybe something simple, or even an KDE bug.
Device: Lenovo Yoga X390 (Convertible)
OS: Bazzite 40
DE: KDE
Image: Other Laptop / Desktop
Language: German
Symptoms: If I want to change the virtual keyboard (Maliite) layout, I only see English as language and checked. If I want to open the Maliite settings I get an KIO Client error: settings://system/language can’t be read
In the spell-checker settings in the KDE preferences, I can only select variants of English
If I add another language in the Region an Language module, I get an error: “The on the system available localizations can’t be found with the localectl tool. Please provide a KDE bug report”
If I run localectl in the terminal I see the locale correctly set as LANG=de_DE.UTF-8
My physical keyboard works correctly, with all German characters working…
I looked around and saw a slightly related bug report for OpenSuse, where some language packages from KDE were missing. With my zero knowledge of Silverblue I assume that they are also missing on Bazzite - But that can be just my inexperience.
The sytem seems stable and workable and it is just a minor inconvenience, as I can long press the keys on Maliite to get to the German characters - Nevertheless I wanted to raise this here, as I have no idea if this is a KDE6 bug, an issue with Maliite, or an issue with Bazzite.
For now it would be great if one could help me identify the issue and potentially missing packages. that I than could layer over the Bazzite install - This is by far the best distro I have tested, supporting all convertible functionality.
