I’m trying to flash Bazzite onto my Legion Go.
However I can’t find a image file download that works.
The main website shows “file not available” I’m also far to casual to try any alternatives.
Can anyone link the file or a different working download link
That link just shows download failed for me.
Then this is on your end. Try a download manager.
Tried download manager and it doesn’t do anything. When attempting to download it says file wasn’t available on site?
Surely that isn’t an issue my end
I’m having the same issue. Trying to download the bazzite-deck-stable image for a Legion Go using a download manager fails or downloads a 4MB file which can’t be used.
I am able to download the bazzite-deck-gnome-stable image successfully so I’m using that for now - going through the initial setup on my Legion Go right now.
How is your install of Gnome going. I attempted but on boot it came up with bad shin signature and need to load kernel first
I’ve got it all working fine on my Legion Go so far, haven’t had the issue you’ve described. Definitely prefer KDE though personally so would like to get the bazzite-deck-stable image downloaded properly.
There’s two threads about similar download issues on the Bazzite subreddit currently, looks like the fix there is to try and download using a VPN. I’ll report back if I have any success with this.
@jbrowneuk
Managed to download the KDE ISO today
Great, glad you could download it and thanks for letting me know. I’ll give it a try this weekend when I have some time.
