Atuin no longer installed for Bluefin / Bluefin DX?
I notice that atuin is not longer in the Bluefin images (not in /usr/bin/ and ujust install-atuin is no longer an option).
I can not find reference to this being removed in the ublue-os github so I was wondering if this is a regression or if there’s a reason it was removed?
Tested on fresh install of:
❯ rpm-ostree status
State: idle
Deployments:
● ostree-image-signed:docker://ghcr.io/ublue-os/bluefin-dx:gts
                   Digest: sha256:05c81c62166a8d06565e9a8325d9107ce6dc8bbf1c1a0564e1a27647d86061c4
                  Version: 39.20240708.0 (2024-07-08T15:29:50Z)
  ostree-image-signed:docker://ghcr.io/ublue-os/bluefin:gts
                   Digest: sha256:f763824aad2761668e5efd2806882f56470169a337f223c85d3a47b5023ea1fe
                  Version: 39.20240708.0 (2024-07-08T15:24:53Z)
Thanks :slight_smile:
Atuin is no longer in the image, you have 2 existing options:
  • brew install atuin and then set it up yourself, here are the docs for that: https://docs.atuin.sh/ (You can skip the installation step in the docs)
  • ujust bluefin-cli will install it and some other tools. This one is fully automatic but may be too opinionated for your taste, adjust as necessary.
