Applications opened through Bazaar do not quit properly
I have Fedora Media Writer installed through Bazaar. When I open Bazaar, go to the “Installed” tab, click on Fedora Media Writer, and then click the “Open” button, Fedora Media Writer opens normally.
However, after I close Fedora Media Writer (using the “X” on the top right corner of the window), in System Monitor, I still see an entry for Fedora Media Writer under “Applications”, and it shows that it is still using memory.
If I instead open Fedora Media Writer through the Application Launcher and then close it (using the “X” on the top right corner of the window), the entry for Fedora Media Writer in System Monitor disappears as expected.
REport this to Bazaars github as its more of an issue with Bazaar than our images.
Same issues with shortwave, deluge and few other apps. They need to be close in task manager.
