Any way to stream audio to my stereo?
Hey, I have a Denon Bluetooth/Airplay/DLNA enabled AV receiver, that I can use with my Android phone (Bluetooth and Airplay) and MacBook to stream audio to. But so far everything I’ve tried to set it up with my Framework 13 laptop running Bluefin GTS has failed in some way or other.
Has anyone with a similar laptop succeeded in sending audio wirelessly to a receiver like mine, using Bluetooth, DLNA or Airplay?
This would be helpful to know. How did it fail?
I use Bluetooth headphones with Bluefin, pairing the receiver should work the same.
It was some time ago that I last tried it so I can’t really recall how my attempts failed, but after following that link it worked! Must have been doing something wrong. Thanks!
