If you’re in the the update window you might have an issue with podman, rendering it broken on your system, including your distroboxes. This only affects Fedora 39-based images so if you’re on 38 you should be fine.
Due to this issue in podman we’ve pinned Podman to 4.7.2:
Thanks to Kyle Gospo and Robert Sturla for committing the fix. When the issue is resolved we’ll remove the pin.
If you do experience this issue a just update and reboot should get you back up to speed. Thanks!
