Bluefin and Aurora 3.5
Another roll up release of the things that have been landing since last time, we’ve started seeding Podman Desktop on to the DX ISOs now. Give it a shot!
Preparing for Fedora 41
You can keep track of release progress by subscribing to either or both of these issues.
3.5.0 (2024-10-04)
Features
Bug Fixes
Will these uodates trickle into the stable 39 of bluefin? Cant be bothered with beta or latest i just want to use the pc get work done and get off it
You probably already have most of these, and the ones that landed last week will be in tonight’s gts build.
I got the 20241006 build for aurora-dx-nvidia:latest but I’m not seeing Podman Desktop.
Also is the rechunker in there now? I’m assuming so because I just ran the update for tonight’s build and it’s showing only 880MB. It seemed to process much faster.
Podman desktop is seeded in the ISO, if you have an existing installation you can install it from the software center and get the same result. And yeah if you’re on latest you’re on rechunker.
