LACT doesn’t apply my customized fan curve on Fsync 6.11.2-201, leading to hotter than usual temps due to the fan not using my specified settings - e.g. staying at 0 RPM at 57°C despite having configured to run at 30% at 50°C. When I tried to make curve changes it gave me an error with something along the lines of could not read pp_od_clk_voltage.
Rolled back to a deployment running Fsync 6.10.8-201 and the saved fan curve is applied, and further changes made to it are also applied.
Affected packages in this upgrade (downgrade) transaction, for further info. I don't think anything other than the kernel packages are relevant though
rpm-ostree db diff --changelogs
ostree diff commit from: rollback deployment (4d9f2378cc8067a7fbddb33aad7d477ee14db1f4df853c6f9bb512592bad41c3)
ostree diff commit to: booted deployment (1a6108df9d3ffadf33d78feeb0d819be5cd00a380926076af0d1ed793a3e9dff)
Downgraded:
codium 1.94.1.24283-el8.x86_64 -> 1.94.0.24281-el8.x86_64
containers-common 5:0.60.4-1.fc40.noarch -> 5:0.60.2-2.fc40.noarch
containers-common-extra 5:0.60.4-1.fc40.noarch -> 5:0.60.2-2.fc40.noarch
hwdata 0.388-1.fc40.noarch -> 0.387-1.fc40.noarch
javascriptcoregtk4.1 2.46.1-1.fc40.x86_64 -> 2.44.3-2.fc40.x86_64
javascriptcoregtk6.0 2.46.1-1.fc40.x86_64 -> 2.44.3-2.fc40.x86_64
kernel 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-core 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-devel 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-headers 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-modules 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-modules-core 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
kernel-modules-extra 6.11.2-201.fsync.fc40.x86_64 -> 6.10.8-201.fsync.fc40.x86_64
mesa-dri-drivers 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-filesystem 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-libEGL 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-libGL 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-libgbm 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-libglapi 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-libxatracker 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-va-drivers 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mesa-vulkan-drivers 1:24.1.7-1.fc40.x86_64 -> 1:24.1.6-1.fc40.x86_64
mtools 4.0.45-1.fc40.x86_64 -> 4.0.44-1.fc40.x86_64
python-pip-wheel 23.3.2-2.fc40.noarch -> 23.3.2-1.fc40.noarch
python3-boto3 1.35.29-1.fc40.noarch -> 1.35.25-1.fc40.noarch
python3-botocore 1.35.29-1.fc40.noarch -> 1.35.25-1.fc40.noarch
qt6pas 6.2.8-30601.fc40.x86_64 -> 6.2.8-30401.fc40.x86_64
rav1e-libs 0.7.1-4.fc40.x86_64 -> 0.7.1-2.fc40.x86_64
selinux-policy 40.28-1.fc40.noarch -> 40.27-1.fc40.noarch
selinux-policy-targeted 40.28-1.fc40.noarch -> 40.27-1.fc40.noarch
unbound-anchor 1.21.1-3.fc40.x86_64 -> 1.20.0-1.fc40.x86_64
unbound-libs 1.21.1-3.fc40.x86_64 -> 1.20.0-1.fc40.x86_64
virtualbox-guest-additions 7.1.2-1.fc40.x86_64 -> 7.1.0-3.fc40.x86_64
webkit2gtk4.1 2.46.1-1.fc40.x86_64 -> 2.44.3-2.fc40.x86_64
webkitgtk6.0 2.46.1-1.fc40.x86_64 -> 2.44.3-2.fc40.x86_64
xxhash-libs 0.8.2-4.fc40.x86_64 -> 0.8.2-2.fc40.x86_64
Just wanted to confirm if others are experiencing this too or give a heads’ up to others. Fsync 6.11.2-201 first finished building midnight UTC yesterday.
GPU model is AMD Navi 23 [Radeon RX 6600/6600 XT/6600M].
LACT version is 0.5.6-release (commit fa0eb30) on both kernel versions. The only (seemingly) relevant change is the kernel version.
