Hi there ublue community! ![]()
First of all, thank you to everyone involved in this amazing project!
Been running ublue, specifically Aurora, for about a month now and it seems to be exactly what I was looking for!
However, I am currently facing an issue when trying to update via rpm-ostree. It seems to crash right after staging the deployment. I first encountered this yesterday and while I was able to update yesterday by booting into a previous deployment and update from there, it still seems to be broken.
❯ rpm-ostree status
State: idle
Deployments:
● ostree-image-signed:docker://ghcr.io/nihaiden/aurora-dx:39
Digest: sha256:d9293379177796ee0d8e2d96681d037cfa582fbd2fceb7725c63aa4cfb57594b
Version: 39.20240403.0 (2024-04-03T22:57:24Z)
LayeredPackages: yakuake
Pinned: yes
Digest: sha256:9230201a51c19466fbbc8351bee56969aae566a967ea5514ea136a00b8238e60
Version: 39.20240309.0 (2024-03-09T16:52:52Z)
Pinned: yes
❯ rpm-ostree upgrade
Pulling manifest: ostree-image-signed:docker://ghcr.io/nihaiden/aurora-dx:39
Importing: ostree-image-signed:docker://ghcr.io/nihaiden/aurora-dx:39 (digest: sha256:31217b7474311aef96ad1aa1f14bd16c23121bc41c0cfc30b9d8da2301b8e935)
ostree chunk layers already present: 60
ostree chunk layers needed: 5 (328,1 MB)
custom layers needed: 3 (1,7 GB)
Checking out tree 2b108be... done
Enabled rpm-md repositories: copr:copr.fedorainfracloud.org:ublue-os:akmods updates fedora rpmfusion-free-updates-testing rpmfusion-free-updates rpmfusion-free rpmfusion-nonfree-updates-testing rpmfusion-nonfree-updates rpmfusion-nonfree updates-archive
Updating metadata for 'updates'... done
Updating metadata for 'updates-archive'... done
Importing rpm-md... done
rpm-md repo 'copr:copr.fedorainfracloud.org:ublue-os:akmods' (cached); generated: 2024-03-17T06:02:48Z solvables: 216
rpm-md repo 'updates'; generated: 2024-04-05T02:28:11Z solvables: 25499
rpm-md repo 'fedora' (cached); generated: 2023-11-01T00:12:39Z solvables: 70825
rpm-md repo 'rpmfusion-free-updates-testing' (cached); generated: 2024-03-31T11:47:48Z solvables: 6
rpm-md repo 'rpmfusion-free-updates' (cached); generated: 2024-03-31T11:47:41Z solvables: 170
rpm-md repo 'rpmfusion-free' (cached); generated: 2023-11-04T16:49:08Z solvables: 445
rpm-md repo 'rpmfusion-nonfree-updates-testing' (cached); generated: 2024-03-31T12:15:07Z solvables: 2
rpm-md repo 'rpmfusion-nonfree-updates' (cached); generated: 2024-03-31T12:14:57Z solvables: 74
rpm-md repo 'rpmfusion-nonfree' (cached); generated: 2023-11-04T17:26:32Z solvables: 208
rpm-md repo 'updates-archive'; generated: 2024-04-04T01:11:00Z solvables: 40351
Checking out packages... done
Running pre scripts... done
Running post scripts... done
Running posttrans scripts... done
Writing rpmdb... done
Writing OSTree commit... done
Staging deployment... done
error: Bus owner changed, aborting. This likely means the daemon crashed; check logs with `journalctl -xe`.
Looking in journalctl as suggested, I can find the following stacktrace:
Apr 05 13:15:16 framework-jan systemd-coredump[7959]: Process 3737 (rpm-ostree) of user 0 dumped core.
Module libnss_resolve.so.2 from rpm systemd-254.10-1.fc39.x86_64
Module libnss_mdns4_minimal.so.2 from rpm nss-mdns-0.15.1-9.fc39.x86_64
Module libsasldb.so from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module libplain.so from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module liblogin.so from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module libkdexoauth2.so from rpm libkgapi-23.08.5-1.fc39.x86_64
Module libgssapiv2.so from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module libanonymous.so from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module libnss_myhostname.so.2 from rpm systemd-254.10-1.fc39.x86_64
Module libnss_systemd.so.2 from rpm systemd-254.10-1.fc39.x86_64
Module libnss_sss.so.2 from rpm sssd-2.9.4-1.fc39.x86_64
Module libnss_altfiles.so.2 from rpm nss-altfiles-2.23.0-1.fc39.x86_64
Module libcrypt.so.2 from rpm libxcrypt-4.4.36-2.fc39.x86_64
Module libbrotlicommon.so.1 from rpm brotli-1.1.0-1.fc39.x86_64
Module libsasl2.so.3 from rpm cyrus-sasl-2.1.28-11.fc39.x86_64
Module libevent-2.1.so.7 from rpm libevent-2.1.12-9.fc39.x86_64
Module libkeyutils.so.1 from rpm keyutils-1.6.3-1.fc39.x86_64
Module libkrb5support.so.0 from rpm krb5-1.21.2-3.fc39.x86_64
Module libcom_err.so.2 from rpm e2fsprogs-1.47.0-2.fc39.x86_64
Module libk5crypto.so.3 from rpm krb5-1.21.2-3.fc39.x86_64
Module libkrb5.so.3 from rpm krb5-1.21.2-3.fc39.x86_64
Module libunistring.so.5 from rpm libunistring-1.1-5.fc39.x86_64
Module libbrotlidec.so.1 from rpm brotli-1.1.0-1.fc39.x86_64
Module libgssapi_krb5.so.2 from rpm krb5-1.21.2-3.fc39.x86_64
Module libpsl.so.5 from rpm libpsl-0.21.2-4.fc39.x86_64
Module libssh.so.4 from rpm libssh-0.10.6-2.fc39.x86_64
Module libidn2.so.0 from rpm libidn2-2.3.7-1.fc39.x86_64
Module libnghttp2.so.14 from rpm nghttp2-1.55.1-4.fc39.x86_64
Module libblkid.so.1 from rpm util-linux-2.39.3-6.fc39.x86_64
Module libattr.so.1 from rpm attr-2.5.1-8.fc39.x86_64
Module libyaml-0.so.2 from rpm libyaml-0.2.5-12.fc39.x86_64
Module libzck.so.1 from rpm zchunk-1.4.0-1.fc39.x86_64
Module libcurl.so.4 from rpm curl-8.2.1-4.fc39.x86_64
Module librpm_sequoia.so.1 from rpm rust-rpm-sequoia-1.6.0-1.fc39.x86_64
Module liblua-5.4.so from rpm lua-5.4.6-3.fc39.x86_64
Module libpopt.so.0 from rpm popt-1.19-3.fc39.x86_64
Module libpcre2-8.so.0 from rpm pcre2-10.42-1.fc39.2.x86_64
Module libselinux.so.1 from rpm libselinux-3.5-5.fc39.x86_64
Module libmount.so.1 from rpm util-linux-2.39.3-6.fc39.x86_64
Module libgmodule-2.0.so.0 from rpm glib2-2.78.3-1.fc39.x86_64
Module libffi.so.8 from rpm libffi-3.4.4-4.fc39.x86_64
Module libxml2.so.2 from rpm libxml2-2.10.4-3.fc39.x86_64
Module libbz2.so.1 from rpm bzip2-1.0.8-16.fc39.x86_64
Module liblz4.so.1 from rpm lz4-1.9.4-4.fc39.x86_64
Module libzstd.so.1 from rpm zstd-1.5.6-1.fc39.x86_64
Module liblzma.so.5 from rpm xz-5.4.4-1.fc39.x86_64
Module libacl.so.1 from rpm acl-2.3.1-9.fc39.x86_64
Module libostree-1.so.1 from rpm ostree-2024.5-1.fc39.x86_64
Module libz.so.1 from rpm zlib-1.2.13-4.fc39.x86_64
Module libcrypto.so.3 from rpm openssl-3.1.1-4.fc39.x86_64
Module libssl.so.3 from rpm openssl-3.1.1-4.fc39.x86_64
Module libmodulemd.so.2 from rpm libmodulemd-2.15.0-5.fc39.x86_64
Module libsolv.so.1 from rpm libsolv-0.7.28-1.fc39.x86_64
Module libsolvext.so.1 from rpm libsolv-0.7.28-1.fc39.x86_64
Module librepo.so.0 from rpm librepo-1.17.1-1.fc39.x86_64
Module libjson-c.so.5 from rpm json-c-0.17-1.fc39.x86_64
Module libsystemd.so.0 from rpm systemd-254.10-1.fc39.x86_64
Module librpmio.so.10 from rpm rpm-4.19.1.1-1.fc39.x86_64
Module librpm.so.10 from rpm rpm-4.19.1.1-1.fc39.x86_64
Module libglib-2.0.so.0 from rpm glib2-2.78.3-1.fc39.x86_64
Module libgio-2.0.so.0 from rpm glib2-2.78.3-1.fc39.x86_64
Module libpolkit-gobject-1.so.0 from rpm polkit-123-1.fc39.1.x86_64
Module libgobject-2.0.so.0 from rpm glib2-2.78.3-1.fc39.x86_64
Module libarchive.so.13 from rpm libarchive-3.7.1-1.fc39.x86_64
Module libjson-glib-1.0.so.0 from rpm json-glib-1.8.0-1.fc39.x86_64
Module libcap.so.2 from rpm libcap-2.48-9.fc39.x86_64
Module rpm-ostree from rpm rpm-ostree-2024.4-3.fc39.x86_64
Stack trace of thread 6559:
#0 0x00007f9378c4f834 __pthread_kill_implementation (libc.so.6 + 0x90834)
#1 0x00007f9378bfd8ee raise (libc.so.6 + 0x3e8ee)
#2 0x00007f9378be58ff abort (libc.so.6 + 0x268ff)
#3 0x00007f9379a0e056 g_assertion_message.cold (libglib-2.0.so.0 + 0x20056)
#4 0x00007f9378e42558 split_kernel_args (libostree-1.so.1 + 0xa1558)
#5 0x00007f9378e46f80 ostree_kernel_args_append (libostree-1.so.1 + 0xa5f80)
#6 0x00007f9378e47147 ostree_kernel_args_append_argv_filtered (libostree-1.so.1 + 0xa6147)
#7 0x00007f9378e29e60 _ostree_deployment_set_bootconfig_from_kargs (libostree-1.so.1 + 0x88e60)
#8 0x00007f9378e601bc sysroot_initialize_deployment.constprop.0 (libostree-1.so.1 + 0xbf1bc)
#9 0x00007f9378e2c033 ostree_sysroot_stage_tree_with_options (libostree-1.so.1 + 0x8b033)
#10 0x0000564f4966ccf7 rpmostree_sysroot_upgrader_deploy (rpm-ostree + 0x293cf7)
#11 0x0000564f4962a63b _ZL26deploy_transaction_executeP22_RpmostreedTransactionP13_GCancellablePP7_GError (rpm-ostree + 0x25163b)
#12 0x0000564f4961bf90 _ZL26transaction_execute_threadP6_GTaskPvS1_P13_GCancellable (rpm-ostree + 0x242f90)
#13 0x00007f9379bef774 g_task_thread_pool_thread (libgio-2.0.so.0 + 0xb7774)
#14 0x00007f9379a7edb2 g_thread_pool_thread_proxy.lto_priv.0 (libglib-2.0.so.0 + 0x90db2)
#15 0x00007f9379a7a523 g_thread_proxy (libglib-2.0.so.0 + 0x8c523)
#16 0x00007f9378c4d897 start_thread (libc.so.6 + 0x8e897)
#17 0x00007f9378cd4a5c __clone3 (libc.so.6 + 0x115a5c)
Stack trace of thread 3811:
#0 0x00007f9378cc6e3d __poll (libc.so.6 + 0x107e3d)
#1 0x00007f9379aa4eb4 g_main_context_iterate_unlocked.isra.0 (libglib-2.0.so.0 + 0xb6eb4)
#2 0x00007f9379a47ad3 g_main_context_iteration (libglib-2.0.so.0 + 0x59ad3)
#3 0x0000564f4960fcdc rpmostree_builtin_start_daemon (rpm-ostree + 0x236cdc)
#4 0x0000564f4960a3de _ZN12rpmostreecxx14rpmostree_mainEN4rust10cxxbridge15SliceIKNS1_3StrEEE (rpm-ostree + 0x2313de)
#5 0x0000564f49603404 rpmostreecxx$cxxbridge1$rpmostree_main (rpm-ostree + 0x22a404)
#6 0x0000564f49904c7c _ZN14rpmostree_rust3ffi14rpmostree_main17hbb3cd952e5524884E (rpm-ostree + 0x52bc7c)
#7 0x0000564f495c8d98 _ZN5tokio7runtime4task3raw4poll17h23652abd376cffd4E (rpm-ostree + 0x1efd98)
#8 0x0000564f49cb3663 _ZN3std10sys_common9backtrace28__rust_begin_short_backtrace17h7326b76817e1f983E (rpm-ostree + 0x8da663)
#9 0x0000564f49cb47bd _ZN4core3ops8function6FnOnce40call_once$u7b$$u7b$vtable.shim$u7d$$u7d$17h7a74a56e731c2ff6E (rpm-ostree + 0x8db7bd)
#10 0x0000564f49d19795 _ZN3std3sys4unix6thread6Thread3new12thread_start17h067379cbc031a159E (rpm-ostree + 0x940795)
#11 0x00007f9378c4d897 start_thread (libc.so.6 + 0x8e897)
#12 0x00007f9378cd4a5c __clone3 (libc.so.6 + 0x115a5c)
Stack trace of thread 3815:
#2 0x00007f9379a4b447 g_main_loop_run (libglib-2.0.so.0 + 0x5d447)
#3 0x00007f9379c54592 gdbus_shared_thread_func.lto_priv.0 (libgio-2.0.so.0 + 0x11c592)
#4 0x00007f9379a7a523 g_thread_proxy (libglib-2.0.so.0 + 0x8c523)
#5 0x00007f9378c4d897 start_thread (libc.so.6 + 0x8e897)
#6 0x00007f9378cd4a5c __clone3 (libc.so.6 + 0x115a5c)
Stack trace of thread 3813:
#3 0x00007f9379a47b29 glib_worker_main (libglib-2.0.so.0 + 0x59b29)
Stack trace of thread 3737:
#0 0x00007f9378cd4e62 epoll_wait (libc.so.6 + 0x115e62)
#1 0x0000564f49cce172 _ZN3mio4poll4Poll4poll17h51f7985e6c22c33cE (rpm-ostree + 0x8f5172)
#2 0x0000564f49cbecb7 _ZN5tokio7runtime2io6driver6Driver4turn17h0c24b7b5e974ec18E (rpm-ostree + 0x8e5cb7)
#3 0x0000564f49cc0b26 _ZN5tokio7runtime4time6Driver13park_internal17h0ad0738478a5c1a8E (rpm-ostree + 0x8e7b26)
#4 0x0000564f49cbdf91 _ZN5tokio7runtime9scheduler14current_thread7Context4park17h0b0740b25f3c759eE (rpm-ostree + 0x8e4f91)
#5 0x0000564f49601e88 _ZN10rpm_ostree4main17h5b28a65e60637af5E (rpm-ostree + 0x228e88)
#6 0x0000564f4959e306 _ZN3std10sys_common9backtrace28__rust_begin_short_backtrace17ha279d27be3640aecE (rpm-ostree + 0x1c5306)
#7 0x0000564f495a29ec _ZN3std2rt10lang_start28_$u7b$$u7b$closure$u7d$$u7d$17h77ecae052b4313d1E (rpm-ostree + 0x1c99ec)
#8 0x0000564f49d009c1 _ZN3std2rt19lang_start_internal17hd4969f33a050e23bE (rpm-ostree + 0x9279c1)
#9 0x0000564f49602417 main (rpm-ostree + 0x229417)
#10 0x00007f9378be714a __libc_start_call_main (libc.so.6 + 0x2814a)
#11 0x00007f9378be720b __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2820b)
#12 0x0000564f49551935 _start (rpm-ostree + 0x178935)
Stack trace of thread 3814:
#0 0x00007f9378cd285d syscall (libc.so.6 + 0x11385d)
#1 0x00007f9379aa1b2d g_cond_wait (libglib-2.0.so.0 + 0xb3b2d)
#2 0x00007f9379a1522b g_async_queue_pop_intern_unlocked (libglib-2.0.so.0 + 0x2722b)
#3 0x00007f9379a7e393 g_thread_pool_spawn_thread (libglib-2.0.so.0 + 0x90393)
ELF object binary architecture: AMD x86-64
Running ostree’s fsck finds an error, though I am not sure how to go about fixing this or if it is even related. Could I simply run sudo ostree fsck -a --delete?
❯ sudo ostree fsck -a
Validating refs...
Validating refs in collections...
Enumerating commits...
Verifying content integrity of 130 commit objects...
fsck objects (145317/205920) [========= ] 70%In commits b664e2e5d6a71764762e1fc8f3811a1f3d505d8994951bb936fbb135fa7426fc, 52ac9beeb873e3577b3be8aeeed66b94452f83b004ec190a114b8fec0bf58df9, a96124a5494aa0225c630e32de6c84aed8fdb8cf3e272fac897d9fabd58e4efa, 9f5452967134d193c66e96d63d76e7bf1c99b5f7c503e752d091534fe8270d5c: fsck content object e2b13cdbe0ef6facc26c5938f51bcb18d5fc293d65ab846d19e3ce8c63df38f5: Corrupted file object; checksum expected='e2b13cdbe0ef6facc26c5938f51bcb18d5fc293d65ab846d19e3ce8c63df38f5' actual='933b8b10b69525ffe6c613f3a30e71b2a610432b40f29df5f9c60db06900b02b'
fsck objects (205920/205920) [=============] 100%
error: Repository corruption encountered
Apologies if this is the wrong place to ask, any help is highly appreciated!
