Zotac Zone - Bazzite 42 Removes Button Functionality
Hey everyone,
I was having some bugs with Bazzite 41, so I thought I would try and reinstall it. Heading over to the Bazzite it seemed that only 42 was avaliable. I tried the beta version first, that seemed to work much better on the device with less bugs, but now I was missing the “Zotac Zone” / Xbox Button functionality and the “Quick Access Menu” button also doesn’t work. I need the QAM button to work in order to access handheld daemon to change the TDP of the device. The same thing is happening in the non-beta version.
Additionally, running “Input Remapper” the software recognizes the inputs, but i’m unsure on how to setup a configuration to give the buttons back their original functionality.
I just wanted to know if anyone could help me out or had a solution.
If you need any more information please let me.
Can you use the Gyro on the Zotac Zone?
@Jonathan_Scheidig , To be honest I never knew the device had gyro in the first place so i’ve never tested it.
It’s been a couple months since I posted this and I have been able to use the lastest versions of bazzite to regain most of button functionality. The only ones that don’t work are the dials around the joysticks and the two back buttons.
