Can't get shortcuts to work with keyboard on bazzite
I have a problem that I can’t get shortcuts to work with the keyboard on bazzite. I press the button that is on the screen. But it doesn’t work. Thanks in advance.
Try adding a key in to whatever combination of keys your doing it worked for me. It wouldn’t allow me to just use the single key as a short cut so instead I added ctrl to the combination and it worked. I assume this is because the said key is already being used as keyboard by something within the operating system. But it doesn’t state that instead it does nothing like you never pressed the key. That or keyboard shortcut can only be trigger by special keys. These are assumptions, the reason why doesn’t matter to me. I just know it works.
