Hello!
I install bazzite and buttons on my console not working ( 2 buttons work: option and button of QMA). If i switch buttons to dekstop mode, buttons are working, but steam not find controller in controller options.
I use sudo systemctl start hhd@deck in terminal (deck is name user in buzzite OS) and nothing happened. Else, after that i use sudo systemctl enable hhd@deck in terminal, and nothing happened.
But i can open HHD from QMA.
Okay it turns out the Aokzoe A1 isn’t well supported here. Do you have a Discord account? It needs an old ChimeraOS kernel patch which isn’t in Bazzite unfortunately.
Yes, i have discord
grg1996 - accont name
Join our Discord and make a post in #bazzite-help to see if others have any ideas.
