XMG Oasis on Bazzite
I have an XMG Oasis rady laptop with the Oasis watercooling device. It works on windows but if possible I’d like to get it working under Bazzite as well.
XMG support pointed me towards their Linux alter ego the Tuxedo computers and their software at: Add TUXEDO Computers software package sources - Add TUXEDO software package sources - TUXEDO Computers
It gives info how to add Fedora repository and install it, but can anyone help me how to get this down on Bazzite?
I think it should be the same now, since we have dnf as well now that that’s not just tied to rpm-ostree.
Though, I personally would use the image-template and add it to the build.sh (or use Blue Build which has a lot more documentation) since, in case of issues, the updates wouldn’t delivered to your system image, shifting potential errors to a separate system.
