Will stuff break badly if I miss one or two update windows in Bluefin? Lets say I’m away and switch off my system for a month. That would imply Bluefin will miss four weekly updates. So on the fifth weekly update will it directly “jump” to that image or will it have to install each earlier image and upgrade step by step through those four commits? Will this cause issues and I should always keep the system on and connected?
IT will just jump over the four weeks and import the newest build image.
Nothing in your system will break if you do that, you could go by 10 months without updating then update it, it would just be stuff in your $HOME directory that probably wouldnt like that - Worst case you can manually rebase to older images then to newer ones using the rollback helper (ujust rollback-helper)
