Wifi driver working
Hey folks,
First time using bazzite/fedora distros, I’ve been using debian based distros for the last years.
Problem
After finishing the initial setup and restarting the system following the update, my Wi-Fi adapter stopped listing available networks. However, if I run a manual scan via the CLI using iw dev wlp4s0 scan | grep -E "SSID|freq", the adapter starts showing networks again, but it’s still unable to connect to them.
I’m using:
  • Linux ditro:
    Linux bazzite 6.17.7-ba20.fc43.x86_64 #1 SMP PREEMPT_DYNAMIC Mon Dec 8 23:40:18 UTC 2025 x86_64 GNU/Linux
  • nmcli output
    wlp4s0: disconnected
    “Broadcom and subsidiaries BCM4360”
    wifi (wl), D6:91:F3:A3:36:E4, hw, mtu 1500
  • lspci output
    04:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4360 802.11ac Dual Band Wireless Network
    Adapter [14e4:43a0] (rev 03)
    Subsystem: Broadcom Inc. and subsidiaries Device [14e4:0619]
    Kernel driver in use: wl
    Kernel modules: wl, bcma
And the nmcli output after manual scan too:
wlp4s0: connecting (configuring) to MY_NETWORK
wifi (wl), 4A:EC:0C:AC:D5:7E, hw, mtu 1500
I would like to know if there is anything else I can do. Thank you for any help you can provide.
Log from journal
Dec 21 18:41:41 bazzite NetworkManager[1422]: <warn>  [1766353301.0433] device (wlp4s0): Activation: (wifi) association took too long, failing activation
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.0434] device (wlp4s0): state change: config -> failed (reason 'ssid-not-found', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <warn>  [1766353301.0442] platform-linux: do-change-link[3]: failure 23 (Too many open files in system) (assume success changing address)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.0443] device (wlp4s0): set-hw-addr: set MAC address to 3E:E5:29:D8:96:4F (scanning)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <warn>  [1766353301.0445] device (wlp4s0): Activation: failed for connection 'Logan'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.0446] device (wlp4s0): state change: failed -> disconnected (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-SCAN-FAILED ret=-22
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.0592] device (wlp4s0): supplicant interface state: disconnected -> inactive
Dec 21 18:41:41 bazzite plasmashell[2542]: QWaylandGLContext: Failed to create the decorations EGLContext. Decorations will not be drawn.
Dec 21 18:41:41 bazzite kded6[2525]: Failed to notify "Created too many similar notifications in quick succession"
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5547] policy: auto-activating connection 'Logan' (5f450014-3c3f-4f7e-aebb-3e19e7c3deed)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5550] device (wlp4s0): Activation: starting connection 'Logan' (5f450014-3c3f-4f7e-aebb-3e19e7c3deed)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5551] device (wlp4s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <warn>  [1766353301.5560] platform-linux: do-change-link[3]: failure 23 (Too many open files in system) (assume success changing address)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5560] device (wlp4s0): set-hw-addr: set-cloned MAC address to 4A:EC:0C:AC:D5:7E (stable-ssid)
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5562] device (wlp4s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5563] device (wlp4s0): Activation: (wifi) access point 'Logan' has security, but secrets are required.
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5564] device (wlp4s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5564] sup-iface[be2650f2c95fff59,2,wlp4s0]: wps: type pbc start...
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5716] device (wlp4s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5717] device (wlp4s0): state change: prepare -> config (reason 'none', managed-type: 'full')
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5719] device (wlp4s0): Activation: (wifi) connection 'Logan' has security, and secrets exist.  No new secrets needed.
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5719] Config: added 'ssid' value 'Logan'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5719] Config: added 'scan_ssid' value '1'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5720] Config: added 'bgscan' value 'simple:30:-70:86400'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5720] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5720] Config: added 'auth_alg' value 'OPEN'
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5720] Config: added 'psk' value '<hidden>'
Dec 21 18:41:41 bazzite maliit-keyboard[24212]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Dec 21 18:41:41 bazzite NetworkManager[1422]: <info>  [1766353301.5750] device (wlp4s0): supplicant interface state: inactive -> disconnected
Dec 21 18:41:41 bazzite wpa_supplicant[1511]: wlp4s0: WPS-CANCEL
Dec 21 18:41:41 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-SCAN-FAILED ret=-22 retry=1
Dec 21 18:41:41 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Dec 21 18:41:41 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=BR
Dec 21 18:41:42 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-SCAN-FAILED ret=-22 retry=1
Dec 21 18:41:43 bazzite wpa_supplicant[1511]: wlp4s0: CTRL-EVENT-SCAN-FAILED ret=-22 retry=1
