Wifi detected on bazzite but can't connect
Wifi detected on bazzite but can’t connect
i have a netgear a7000 usb dongle
always searching for connection but never does.
can see all network around including mine
Can you help me i’m new to bazzite
thanks
Are you not getting any errors?
Connection timeout? Anything that could help narrow it down a bit.
stuck in authentification
maybe driver not supported?
Try connecting while having a terminal open running the command journalctl -f
Same issue
