When System Upgrade launched: "httpd-core: Could not find group 'apache' in group file"
I cannot upgrade my Bazzite anymore and get the following Error:
sudo rpm-ostree upgrade
[sudo] Passwort für gerhard:
Pulling manifest: ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-dx:stable
Checking out tree c6741b9... done
Inactive requests:
  code (already provided by code-1.103.1-1755017320.el8.x86_64)
  gnome-disk-utility (already provided by gnome-disk-utility-46.1-2.fc42.x86_64)
Enabled rpm-md repositories: copr:copr.fedorainfracloud.org:ublue-os:akmods charm docker-ce-stable updates fedora rpmfusion-free-updates rpmfusion-free rpmfusion-nonfree-updates rpmfusion-nonfree tailscale-stable terra terra-source code updates-archive
Importing rpm-md... done
rpm-md repo 'copr:copr.fedorainfracloud.org:ublue-os:akmods' (cached); generated: 2025-06-22T03:25:34Z solvables: 121
rpm-md repo 'charm' (cached); generated: 2025-08-20T21:40:26Z solvables: 680
rpm-md repo 'docker-ce-stable' (cached); generated: 2025-07-28T19:13:38Z solvables: 45
rpm-md repo 'updates' (cached); generated: 2025-08-23T01:08:22Z solvables: 22462
rpm-md repo 'fedora' (cached); generated: 2025-04-09T11:06:59Z solvables: 76879
rpm-md repo 'rpmfusion-free-updates' (cached); generated: 2025-08-13T21:55:23Z solvables: 84
rpm-md repo 'rpmfusion-free' (cached); generated: 2025-04-12T09:12:27Z solvables: 358
rpm-md repo 'rpmfusion-nonfree-updates' (cached); generated: 2025-08-13T22:19:26Z solvables: 59
rpm-md repo 'rpmfusion-nonfree' (cached); generated: 2025-04-12T09:32:45Z solvables: 218
rpm-md repo 'tailscale-stable' (cached); generated: 2025-08-18T15:52:54Z solvables: 122
rpm-md repo 'terra' (cached); generated: 2025-08-23T02:06:49Z solvables: 2896
rpm-md repo 'terra-source' (cached); generated: 2025-08-23T02:06:53Z solvables: 449
rpm-md repo 'code' (cached); generated: 2025-08-21T09:22:13Z solvables: 745
rpm-md repo 'updates-archive' (cached); generated: 2025-08-23T01:45:49Z solvables: 37012
Relabeling... done
Checking out packages... done
Running systemd-sysusers... done
Running pre scripts... done
Running post scripts... done
error: While applying overrides for pkg httpd-core: Could not find group 'apache' in group file
Any idea how to add this group apache as workaround? Can you fix this problem? Thanks in advance.
Got this solved by removing layers I had added previously added and running upgrade again.
