the coreos stable branch migrated to 41 and i remember the developer saying the rebase happens when coreos migrates
Today we will rebase Aurora and Bluefin ontop of F41 in stable.
inffy
November 12, 2024, 4:35pm
3
Actually stable will stay on F40 because the coreos-stable kernel is still the bugged one with tailscale
opened 06:56PM - 31 Oct 24 UTC
bug
upstream
### Describe the bug
When running `tailscale status` on system running `aurora-… dx:latest` (`41.20241030.0`), tailscale prints this failed health check:
# Health check:
# - adding [-i tailscale0 -j MARK --set-mark 0x40000/0xff0000] in v6/filter/ts-forward: running [/usr/sbin/ip6tables -t filter -A ts-forward -i tailscale0 -j MARK --set-mark 0x40000/0xff0000 --wait]: exit status 2: Warning: Extension MARK revision 0 not supported, missing kernel module?
ip6tables v1.8.10 (nf_tables): MARK: bad value for option "--set-mark", or out of range (0-4294967295).
Try `ip6tables -h' or 'ip6tables --help' for more information.
Tailscale pings seem to work correctly otherwise, but DNS does not get configured. I mainly use tailscale for a remote pihole, so I noticed that wasn't working anymore.
### What did you expect to happen?
Tailscale runs without any errors.
### Output of `rpm-ostree status`
State: idle
AutomaticUpdates: stage; rpm-ostreed-automatic.timer: inactive
Deployments:
â—Ź ostree-image-signed:docker://ghcr.io/ublue-os/aurora-dx:latest
Digest: sha256:200c66f230f15fb77450dea9d0910f6992d123a1bbef8d3ce084955214533e43
Version: 41.20241030.0 (2024-10-30T04:44:13Z)
LayeredPackages: bees btop byobu
Digest: sha256:b169896d19967cd89066cf339712f0b19526a4f41a6b5508d421c4cbd7c7e693
Version: 41.20241029.0 (2024-10-29T18:27:51Z)
### Output of `groups`
`apavel wheel docker incus-admin lxd libvirt`
### Extra information or context
_No response_
My bad, it will stay until this issue is fixed.
j0rge
November 12, 2024, 9:41pm
5
We’re good, it’s live, we’re pinned on 6.11.3 so tailscale works as expected. ISOs will fire off later, docs are updated, I’ll post the announcement after the ISOs build. Cheers!
