Way to set it to load into desktop mode first, not big picture
There’s gotta be a way, right?
AFAIK, non deck/htpc versions of Bazzite boot into desktop mode by default. If you are already running deck version, then I believe there is a hidden ujust recipe just for that:
ujust _toggle-autologin
I’m not 100% sure about this and if this recipe is safe or not so maybe someone else can confirm.
Update:
Same question asked here, same answer… same warning :smiley:
Oh I see what I did, when choosing the game scope option it installs the deck version I guess. I appreciate the help, it’s working fine now, no issues :slight_smile:
Maybe you know, but I executed that command and it works great, loads right into desktop environment. Problem now, is the “return to gaming mode” fails and sends me right back to desktop now lol. Is there a way to undo that ujust command?
Well… you can run it again. It will then restore the original behavior. That’s why it’s called a “toggle”. But as noted in a linked comment, it may break things even further.
