Looking for help with getting a Steam Deck LCD setup for playback of DVD and Blu-ray movies and TV shows with VLC using a controller instead of keyboard and mouse control and hopefully do so from game mode instead of desktop mode
I think what you can do is:
- Open Desktop Mode
- Open VLC, go to settings, and take note of the keyboard shortcuts you need
- Add VLC to Steam as a Non-Steam Game
- Navigate to VLC in Steam (Game Mode or Desktop Mode works)
- There should be a gamepad icon, you can use it to edit your keybinds for VLC
- Put in the same keybinds on each buttons as the function you want, based on your notes (say, A = Space = Play/Pause)
Yes but I think having some preconfigured option that could be selected from say a ujust command in future versions of the OS might be kinda cool. I know not everyone will want it to be installed by default but hey it can’t hurt to have something available for me and I assume other people who might be like I want it to be a simple optional install script that is a ujust command away that installs and configures a media center setup.
