Using devcontainers on bazzite
I’m trying to get devcontainersin vscode working, but I don’t know how to install docker.
I guess there are 3 ways
  1. Install vscode and docker in distrobox
  2. Install docker via brew
  3. Layer docker package
    I don’t now which way is the correct one so i’m just asking
    (Yeah i know rebasing to a dx version of aurora is simpler but i like bazzite)
bazzite-dx has docker built in:
I checked the dx site that tells me to rebase, but how can I rebase with this command if I don’t have docker installed?
docker pull ghcr.io/ublue-os/bazzite-dx:sha256-2bf73c66b7b0065988ba72411f317cf829f0be68a6881b2ae59739bc38218287.sig
Should I edit it in some shape or form? Like aurora?
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/aurora:stable
Or maybe use the prompt from amyOS?
sudo bootc switch --enforce-container-sigpolicy ghcr.io/astrovm/amyos:latest
If anyone was looking for - the correct prompt is
rpm-ostree rebase ostree-image-signed:docker://ghcr.io/ublue-os/bazzite-dx:stable
You can change bazzite-dx with any other package listed here
