Upon a clean install of bazzite-deck-nvidia:stable boots into desktop mode and not gaming mode, extra steps were needed to fix
When choosing an image to download, you can select either a desktop or game mode image. The “deck” images are designed to boot directly into game mode, similar to the Steam Deck. If you’re resorting to complex methods to boot into game mode, something is wrong, as a Reddit user pointed out. This would normally be true, but for me, the “deck” images on NVIDIA hardware are booting into desktop mode instead of game mode, which is the issue I’m facing at home. This problem occurs with both Bazzite 42 and Nobara images, as both crash into desktop mode when gaming mode fails to load properly.
A system update is required; otherwise, appears to enter desktop mode. I believe a system update resolves this issue, although I am not entirely sure what steps are necessary to fix the problem., I managed to get it working again by using the top command and the “ujust fix-reset-steam” command. I did __GL_CONSTANT_FRAME_RATE_HINT=3 steam before I used system update, and I also tried ujust fix-reset-steam also before the system update was done, otherwise yes it defaulted to booting into desktop mode instead of gaming mode on a clean install of the iso image that includes kde in gaming mode of bazzite 42.
reddit.com
Reddit - The heart of the internet
That’s the gist of the problem. To fix it on Bazzite, I used a reset-steam-like command I found online: “__GL_CONSTANT_FRAME_RATE_HINT=3 steam reset.” On Nobara, I found the same solution on a different post, which also recommended “__GL_CONSTANT_FRAME_RATE_HINT=3 steam.”
This issue isn’t exclusive to Bazzite; it also affects the Nobara Linux distro images from their website. It seems to be the same problem, and I’ve only tested these images this week.
Is anyone else experiencing this issue? Has a bug report been opened on the Bazzite GitHub page or any GitHub page for the Nobara Linux distro to address this problem?
by the way, I did a clean install using all the images on my older gigabyte desktop, that command is needed on clean installs for the install images, I used my USB drive PNY brand to install it using Universal-USB-Installer-2.0.2.7 version to boot the iso images from the drive, and install them, with that method to my older desktop.
Universal USB Installer: Best Bootable USB Software (UUI)
Couldn’t boot into Gaming Mode , instead the nvidia iso images of bazzite based on fedora 42 boots into desktop mode, steam broken · Issue #2644 · ublue-os/bazzite
Couldn’t boot into Gaming Mode , instead the nvidia iso images of bazzite based on fedora 42 boots into desktop mode, steam broken on both linux distros · Issue #17 · Nobara-Project/nobara-images
Hardware
bazziteGigabytePc:~$ fastfetch
  bazziteGigabytePc
%%%%%%%% %%%%%%%%%%%%%% 󱋩  bazzite-deck-nvidia:stable 
%%%%%%%%% %%%%%%%%%%%%%%%% 󰣛  Bazzite 42 (FROM Fedora Kinoite)
%%%%%%%%% %%%%%%%%%%%%%%%###   Linux 6.14.4-104.bazzite.fc42.x86_64
%%%%%%%%% %%%%%%%%%%%%%###### 󰅐  28 mins
== =========##### 󰻠  Intel(R) Core™ i7-3930K (12) @ 3.80 GHz
%%%%%%%%% %%%%%%%####======##### 󰍛  NVIDIA GeForce RTX 3070 Lite Hash Rate [Discrete]
%%%%%%%%% %%%%%#######=====#####   6.39 GiB / 31.25 GiB (20%)
%%%%%%%%% %%%#########=====#####   41.10 MiB / 41.10 MiB (100%) - overlay [Read-only]
%%%%%%%%% %%##########=====#####   825.53 GiB / 931.50 GiB (89%) - fuseblk
%%%%%%%%%====###########=====######   359.67 GiB / 465.75 GiB (77%) - fuseblk
%%%%%%%%====#########======######   24.00 GiB / 929.93 GiB (3%) - btrfs [Read-only]
%%%%%%%=====#####========###### 󰍹  3840x2160 @ 144 Hz (as 2649x1490) in 31" [External]
%%%%###===============####### 󰖺  Generic X-Box pad
%#######==========######### 󰖺  Microsoft X-Box 360 pad 0
################### 󰕮  KDE Plasma 6.3.5
###########   KWin (Wayland)
  bash 5.2.37
  Ptyxis 48.3
󰏖  2722 (rpm), 45 (flatpak)
the problem affects current download images as of 5/17 or before that based on fedora 42 for bazzite-deck-nvidia-stable-amd64.iso, bazzite-deck-nvidia-gnome-stable-amd64.iso, and Nobara-42-Steam-HTPC-NV-2025-05-13.iso images from their official download sites.
also dmesg got these messages if this helps. all the dmesg ran under console on bazzite 42 build. some of these are seen like Failed to start systemd-remount-fs.service - Remount Root and Kernel File Systems on the linux kernel bootup.
[ 31.172538] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 31.172956] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 31.173358] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 31.173735] systemd[1]: systemd-remount-fs.service: Main process exited, code=exited, status=1/FAILURE
[ 31.174175] systemd[1]: systemd-remount-fs.service: Failed with result ‘exit-code’.
[ 31.174834] systemd[1]: **Failed to start systemd-remount-fs.service - Remount Root and Kernel File Systems.**
[ 31.175548] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 31.176374] systemd[1]: iscsi-onboot.service - Special handling of early boot iSCSI sessions was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/class/iscsi_session).
[ 41.661656] UBSAN: array-index-out-of-bounds in sound/pci/ctxfi/ctamixer.c:347:48
[ 41.661662] index 8 is out of range for type ‘unsigned char [8]’
[ 196.752697] show_signal_msg: 7 callbacks suppressed
[ 196.752700] gldriverquery[3407]: **segfault** at c ip 00000000f7f4b546 sp 00000000fff48d40 error 4 in ed6637b5f7265c49a5123a457ddf2f703149998d6e98e02e72d99ecbb52b8b.file[b546,f7f43000+21000] likely on CPU 11 (core 5, socket 0)
[ 196.752710] Code: 85 c0 78 0e 6b d0 58 8b 4c 24 2c 89 8c 16 24 00 00 00 8b 54 24 10 85 d2 0f 85 f6 00 00 00 83 ec 0c 50 e8 3d 73 ff ff 83 c4 10 <8b> 40 0c 85 c0 0f 85 27 51 ff ff 83 ec 0c 57 ff 96 40 fb ff ff 8b
[ 203.630980] i386-linux-gnu-[3484]: **segfault** at c ip 00000000f7f8d546 sp 00000000ffe46fd0 error 4 in ed6637b5f7265c49a5123a457ddf2f703149998d6e98e02e72d99ecbb52b8b.file[b546,f7f85000+21000] likely on CPU 9 (core 3, socket 0)
[ 203.630992] Code: 85 c0 78 0e 6b d0 58 8b 4c 24 2c 89 8c 16 24 00 00 00 8b 54 24 10 85 d2 0f 85 f6 00 00 00 83 ec 0c 50 e8 3d 73 ff ff 83 c4 10 <8b> 40 0c 85 c0 0f 85 27 51 ff ff 83 ec 0c 57 ff 96 40 fb ff ff 8b
[ 206.842908] i386-linux-gnu-[3594]: **segfault** at c ip 00000000f7f78546 sp 00000000ffbfe040 error 4 in ed6637b5f7265c49a5123a457ddf2f703149998d6e98e02e72d99ecbb52b8b.file[b546,f7f70000+21000] likely on CPU 9 (core 3, socket 0)
[ 206.842919] Code: 85 c0 78 0e 6b d0 58 8b 4c 24 2c 89 8c 16 24 00 00 00 8b 54 24 10 85 d2 0f 85 f6 00 00 00 83 ec 0c 50 e8 3d 73 ff ff 83 c4 10 <8b> 40 0c 85 c0 0f 85 27 51 ff ff 83 ec 0c 57 ff 96 40 fb ff ff 8b
[ 42.007741] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[ 42.008040] snd_hda_intel 0000:02:00.1: enabling device (0000 -> 0002)
[ 42.008096] snd_hda_intel 0000:02:00.1: Disabling MSI
[ 42.008111] snd_hda_intel 0000:02:00.1: Handle vga_switcheroo audio client
[ 42.011559] snd_hda_intel 0000:00:1b.0: **no codecs found!**
[ 42.011862] snd_hda_intel 0000:00:1b.0: device 1458:a002 is on the power_save denylist, forcing power_save to 0
[ 3645.934414] wlp0s29u1u7: association with 2c:00:ab:cd:e5:80 timed out
[ 3652.884223] wlp0s29u1u7: authenticate with 2c:00:ab:cd:e5:80 (local address=32:d9:91:67:55:40)
[ 3652.884231] wlp0s29u1u7: send auth to 2c:00:ab:cd:e5:80 (try 1/3)
[ 3652.885789] wlp0s29u1u7: authenticated
[ 3652.886333] wlp0s29u1u7: associate with 2c:00:ab:cd:e5:80 (try 1/3)
[ 3652.889907] wlp0s29u1u7: RX AssocResp from 2c:00:ab:cd:e5:80 (capab=0x411 status=0 aid=24)
[ 3652.901138] wlp0s29u1u7: associated
[ 3652.953793] wlp0s29u1u7: Limiting TX power to 30 (30 - 0) dBm as advertised by 2c:00:ab:cd:e5:80
[ 4725.201831] pool-23[11113]: **segfault at 8 ip 000056436d2e8b3a sp 00007f2282ffca50 error 4 in 675fe85a4bbe12f7059b7588d8fd9ba241841e77062cb190f013207193a64b.file[50b3a,56436d298000+89000] likely on CPU 7 (core 1, socket 0)**
[ 4725.201847] Code: 02 00 e9 4d ff ff ff 66 0f 1f 84 00 00 00 00 00 48 8b 85 b8 fe ff ff 48 8d 15 bf 50 04 00 be 10 00 00 00 48 8d 3d db 72 04 00 <4c> 8b 40 08 31 c0 e8 7b 22 fb ff e9 80 fe ff ff 48 8d 15 8b 50 04
I found out more about the problem, from reddit pages tonight
a user reply with this information below, I think its related to the problem in question.
Nvidia driver issue.
Solved in beta 575 drivers.
