New: bazzite-deck-nvidia Images
As of today, bazzite-deck-nvidia is now available as a beta thanks to improvements in the latest Nvidia drivers. While this is very clearly not a stable experience everyone should jump on, this should at least give our users something to play with and a tool to help report the remaining bugs to Nvidia.
Some important caveats:
  • Most bugs present here cannot be fixed by us, please do not report them to us if they’re already known issues. See our Discord and/or GitHub issue tracker.
  • This will not allow Nvidia eGPUs on handhelds. Due to issues caused by installing the Nvidia drivers this support most likely won’t come until NVK is ready to replace the proprietary driver.
  • Only nvidia-open will be supported by these images. That means no GTX 9xx or 10xx support.
  • If the UI is laggy, go into desktop mode and open steam settings in the desktop client and make sure Enable GPU accelerated rendering in web views is enabled in the interface settings (enabling this can cause graphical glitches in the steam UI in desktop, Big Picture Mode and gamemode), then return to gamemode.
Let us know what you think!
Me thinks Nvidia is late to the party :crazy_face:
but hey, progress!
If I install it, will it include the normal GNOME, but with this Game Mode option, which if I don’t open it, its same as gnome-nvidia-open? Or is it entirely different from normal GNOME
Your desktop will not change, but deck images boot to game mode first.
Awesome, thank you guys!
I got two questions:
  1. Is the QAM known from SteamOS available on this image too? If so, how do I open it via keyboard?
  2. Is there a way to configure rgb lighting in game mode?
  1. Ctrl/Meta + 2
  2. OpenRGB might work in Desktop Mode and still apply in Steam Gaming Mode depending on the RGB fans.
Thanks for this, I actually downloaded this last week to try it out as I’ve been waiting for a SteamOS experience since I got my steam deck.
My experience didn’t last long, more my own fault I expect as I was in a hurry to get things working but I think I am really your key demographic.
I’ve used Linux back in the days of SUSE, BeOS, Mandrake etc but not played around with Linux in some time so I can tinker if required but I want my experience when doing in on my gaming PC to be seamless (I understand this is an Nvidia/Gamescope issue not yours)
The issues I had was
  1. The choppy UI which I then found the fix for on reddit as I didnt know about this post.
  2. When I tried to play a game it ran at 1 FPS, I was playing Hogwarts Legacy at the time and as this was unplayable I had to roll back to Windows, the issue seem to be it thought my machine had a AMD card and tried to run at 1080p.
My system is a MSI Trident X with a Nvidia 3090 connected to a 60Hz 4K TV.
https://www.msi.com/Desktop/MEG-Trident-X-12th
I can understand why you have released this, and I think it is a good thing as hopefully it will force Nvidia or stream to fix the issues but I think you need a better way for users to report feedback to the right people, you mention " * Most bugs present here cannot be fixed by us, please do not report them to us if they’re already known issues. See our Discord and/or GitHub issue tracker." but how does joe blogs like myself know how to track/report issues to the the right people.
Any ways I look forward to the updates, I will try setup a dual boot so I can keep testing, as soon as this is stable with Nvidia I can remove my Window partition.
Not the best place for this, but all known issues are tracked on the documentation.
Awesome news!
Tried the new ISO on my HTPC with a GTX 1650 and Gaming mode is incredibly laggy. Is this expected behavior?
Try turning on “Enable GPU acceleration” in the Steam settings and let me know if that works. Steam Big Picture Mode without gamescope-session has the same issue under Nvidia drivers.
Amazing, that seems to have fixed it, thank you so much!
First, I would like to thank everyone for their work in making this possible.
I followed the installation normally, and after detecting that the black screen issue was related to the DisplayPort and enabling hardware acceleration, the system worked perfectly.
I would just like to activate the DisplayPort. Could anyone help me with that?
When I connect the DP, the screen automatically freezes on HDMI, and the DP remains black.
I am testing it on my RTX-4060 and it is working great for me so far. It even made it to where one of the games I was getting lag in, is more playable and smoother. Also using the decky plugin for DLSS enable and upscaler, so that may have helped too.
Edit: I’ve noticed one thing, at least for one back, if I am in game and open the deck pane, I can no longer type in game. If I don’t it before starting the game it works as expected
Well the only issue i have is that I get less performance than I got on windows for example OW2 runs at 100-120 fps while on windows i got 300 cap in the training mode.
Maybe i should try NVK driver?
In its current state, NVK will run worse and Steam Gaming Mode won’t work.
unfortunate, I know Nvidia is hard to run on Linux tho I did expect it to run a bit better, or is there a way to manage TDP and clocks?
There’s no reason to touch TDP on a desktop or laptop, clocks can be managed with LACT on supported hardware. Overclocking will not fix the drivers however and you’ll never overclock enough to make up the difference.
