Upgraded GPU to 9070 xt, Display Problems
I have been using Bazzite for around a year now. I just upgraded my GPU from a 3060 ti to a 9070xt. I re-based my image, keeping the same DE. I have three displays I switch between.
A Lenovo Q27q-10 ,this display works regardless of cord/port used
A Dell 32in S3222DGM, only: source DP->HDMI on display works
and an LG A2, no cords or combinations of them work
the display is half black and the top half looks like a lot of frames shifted and stack on each other, this is the case for all failures.
I only have 2 displays on at max. The 3060ti had no problems with any display or cords used
system info:
any insights would be greatly appreciated!
Don’t know if this will be helpful:
This did not fix the issue unfortunately, thank you for the reply though!
I found a complete solution to the post he reccommended and it was pasting KWIN_DRM_NO_AMS=1 into etc/environment. No clue if it will help but I figured I’d let you know the post that was recomended to you has been updated.
