I don’t really understand how I could sign my own custom image.
rpm-ostree status shows
ostree-unverified-registry:ghcr.io/manfredlotz/aurora-dx-nvidia-open-asus-aso:latest
I tried to set the repository id in file artifacthub-repo.yml but wasn’t yet successful as I am not totally sure how to find the repository id.
I looked here https://api.github.com/repos/manfredlotz/aurora-dx-nvidia-open-asus-aso and thought that the node_id in line 2 is the correct one. But it didn’t help to get the image signed.
Next I tried the node_id in the owner section but it didn’t work either.
As I am a dummy here any help would be appreciated.
renner
November 8, 2025, 4:20pm
2
Start here:
Build your own custom Universal Blue Image!
If you followed this already then you may just need to rebase to your signed image
sudo bootc switch --enforce-container-sigpolicy ghcr.io/manfredlotz/aurora-dx-nvidia-open-asus-aso:latest
Thanks a lot. This command I have missed.
But I am not sure about the id I have to add to the artifucthub-repo.yml Is it the node_id value at the very top at https://api.github.com/repos/manfredlotz/aurora-dx-nvidia-open-asus-aso ?
Thinking about these things: Could it be that the artifucthub-repo.yml simply has nothing to do with signing the image???
Thanks for that! I missed that a well, switching to the enforced opion.
I just noticed mine was the same thing. I think it’s because I look at my image using bootc status and not rpm-ostree status. bootc does not show that information.
renner
November 9, 2025, 4:46am
7
Yes, that’s metadata for artifacthub, it’s so other people can find your custom image more easily.
You don’t have to touch any of that if you don’t care about that.
This has nothing to do with signing.
