Failed to invoke method OpenImage: A signature was required, but no signature exists
A few days ago, I set up a custom image based on quay[.]io/fedora-ostree-desktops/silverblue:42
However, I’ve hit a brick wall. I’ve been unable to rebase to the signed image and currently can’t upgrade my system.
I get the following when trying to rebase
$ sudo bootc switch --enforce-container-sigpolicy ghcr.io/myGithub/fedora-bootc:latest
ERROR Switching: Pulling: Creating importer: failed to invoke method OpenImage: failed to invoke method OpenImage: A signature was required, but no signature exists
My bootc status is the following
$ sudo bootc status
● Booted image: ghcr.io/myGithub/fedora-bootc:latest
        Digest: sha256:ff05513f713d3d9d6b0df797c262d1e50f49fc33cae371639f202b4021f4af3c
       Version: latest (2025-03-10 20:28:35 UTC)
  Rollback image: ghcr.io/myGithub/fedora-bootc:latest
          Digest: sha256:fdaca628329c4b7eaa5f89e95a1b8422d7cb0ce3a97907fc7f065198fa9602ee
         Version: latest (2025-03-10 19:07:27 UTC)
My rpm-ostree status is the following
$ rpm-ostree status
State: idle
AutomaticUpdates: stage; rpm-ostreed-automatic.timer: inactive
Deployments:
● ostree-unverified-registry:ghcr.io/myGithub/fedora-bootc:latest
                  Version: latest (2025-03-10T20:31:33Z)
                  Version: latest (2025-03-10T19:09:36Z)
My /etc/containers/policy.json is the following
  "default": [
      "type": "insecureAcceptAnything"
  "transports": {
    "docker-daemon": {
    "docker": {
      "ghcr.io/myGithub/fedora-bootc": [
          "type": "sigstoreSigned",
          "keyPath": "/etc/pki/containers/myGithub_fedora-bootc.pub",
          "signedIdentity": {
            "type": "matchRepository"
and to verify that the key does exist,
$ ls /etc/pki/containers/myGithub_fedora-bootc.pub
The only reason that comes to mind why this is not working is that according to Fedora’s “Roadmap to Fedora Bootable Containers” (Roadmap to Fedora Bootable Containers (#26) · Issues · fedora / Fedora Atomic Desktops / SIG Issue Tracker · GitLab), under “Switching to composefs” they mention that they are currently not using signatures. Does this mean my derived container also has no signature?
Were you able to sort this out @that_leaflet ?
Yes. I don’t remember my exact solution, but I made some changes to my container stuff that I automated in my build.sh.
I created /etc/containers/policy.json with the following contents
  "default": [
      "type": "reject"
  "transports": {
    "docker": {
      "ghcr.io/myGithubUserName": [
          "keyPath": "/etc/pki/containers/myGithubUserName.pub",
          "signedIdentity": {
    "docker-daemon": {
I created /etc/containers/registries.d/myGithubUserName with the following contents
docker:
    ghcr.io/myGithubUserName:
        use-sigstore-attachments: true
Now that I’m looking at this again, I believe the issue was my original policy file. I eventually figured out the issue while looking at Ublue’s policies and how they do it.
Hmm okay thanks. Both those files already exist in my case and look correct.
I figured it out…
I was able to solve it like so:
sudo bootc switch ghcr.io/myUser/myImage
reboot
sudo bootc status now properly shows the correct image.
The issue was the missing yaml file specifying to use sigstore attachments.
