Ujust error
I am getting:
ndowens@Revan ~> ujust
You must run ujust inside a container!
I am using blue-build with some extra packages installed. I haven’t touched the justfile related to it or anything. I have searched code from bazzite’s github and u-blue github to find a hint of a check and see what the check is looking for; I was not able to find anything code related and generic web search did not give any pointers.
I am hoping someone can point me in the right direction.
P.S. I did ask blue-build about the error and someone said it comes from bazzite and to ask here.
Thanks
Bazzite
Found out, thanks to @mel226 in Discord, which ujust was saying /usr/local/bin/ujust instead of /usr/bin/ujust (which works)
