When: At random times, though every time it’s been while using Firefox (maybe coincidentally). Has happened about 3-4 times in the past few days.
What happens:
- An extension misbehaves randomly (twice where a Firefox extension popped up its setup message even though I already set it up weeks before, and the button don’t work), or Firefox just crashes
- Poweroff/settings/lock icons in Gnome power menu disappear
- Every time except once, I can still open most applications, but they don’t work right. Trying to run terminal commands results in “Input/output error”. Only sh works to move around and list directories, but no files can be read, with Input/output error.
- Can’t open journalctl because of Input/output error.
- Running shutdown results in Failed to execute shutdown binary and every mount point being unable to unmount
- Need to force shutdown with power button
What I’ve tried
- Checking journalctl logs. Nothing of note shows up from the last boot once I reboot, I assume because I/O failed before logs could be written
- Seeing if it’s a hardware issue
- Running smartctl for an SSD check. This is a new PC and SSD, so everything passed.
- Running memcheck86. Everything passed.
- Running btrfs check. Everything was fine.
- Display environment still worked so I don’t see how it’s a GPU issue
I assume it’s some software issue and it just started recently, but I can’t find any logs to figure out what.
System Information
bazzite-gnome:stable
Bazzite 41 (FROM Fedora Silverblue)
Linux 6.13.5-102.bazzite.fc41.x86_64
GNOME 47.4 - Mutter (Wayland)
Anyone have a similar issue? Any help appreciated, thanks
