Hello.
I purchased a MSI BE6500 WIFI 7 USB ADAPTER from Microcenter today, because it was on the list of devices supported by Linux: USB-WiFi/home/USB_WiFi_Adapters_that_are_supported_with_Linux_in-kernel_drivers.md at f9c4b27c1c1cafd92a8c5f504ddf327c28f7ee7a · morrownr/USB-WiFi · GitHub
I can see it when I lsusb
zoey@clippite:~$ lsusb | grep Micro
Bus 003 Device 013: ID 0db0:da0e Micro Star International 802.11be WLAN Adapter
But I can’t seem to figure out how to tell Bazzite that I want to use that device instead of my internal Wifi device on the motherboard.
I attempted to disable the internal device in the BIOS, but then I just… didn’t have network at all, and the “Wifi” configuration screen in Gnome was just gone.
As far as I can tell, there’s a kernel module available for this device, as it’s a Mediatek mt7925 inside, it just doesn’t seem to load on boot?
I’m kinda at my wit’s end here. Any debugging or installation advice would be super helpful.
